20 Most Recent
Hitachi 55HDS69 55 in. Plasma Television Questions & Answers
Hitachi 55HDS 55 Inch Plasma Picture Problem
Hi Mhansen884,
This type of failure is due to a defective upper and lower scan boards.
Check the link provided to see what the parts look like and or to find the part numbers if you would be DYI,
Is my problem the Main Digital Board?
Fault at its main digital board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Blinks times 8
Denotes a y-sustain fault. If you wish to get some details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to
Mosaic / Timeslide / Flipcard, can be
selected by the
drop-down list, at the top left of the display window,
will make surf easy. You can also do a
search, by type in the
brand name / model number / IC used, in the
search box at the top right of the display window. Blinking codes and troubleshooting to Plasma dispays are given in detail.
Set tv
Hello Dchampgus
Which remote are you having the issue with and are you having a problem with programming your box remote or is it the Tv remote
The top half of tv has lots of horizontal lines
Was it dropped?
It sounds like panel has been damaged. There is an array of very fine connections on the top or bottom and the left or right (one each) and if you break the connecitons it looks like you describe.
Does it look like this? http://i16.photobucket.com/albums/b22/Ubermateo/vaioVertLines.jpg ?
-=/ MLF /=-
