20 Most Recent Olympus SP-550 UZ Digital Camera Questions & Answers
2answers
Zoom Error with my Olympus SP-550uz
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
3/5/2019 7:34:35 PM • Olympus SP-550... • Answered on Mar 05, 2019
Jammed power button on Olympus SP-550 Uz digital camera
http://www.olympusamerica.com/cpg_section/cpg_consumercontact.asp click on this link togo to olympus support contact us page
1/30/2018 8:12:37 AM • Olympus SP-550... • Answered on Jan 30, 2018
Olympus SP-550 UZ won't focus properly
If practically new have the auto focus circuitry repaired under warranty. If not under warranty it will cost a pretty penny since working on those units is labor intensive and the parts are proprietary and expensive..
4/25/2017 2:02:54 AM • Olympus SP-550... • Answered on Apr 25, 2017
An error information shows up: ZOOM ERROR
You need to send the camera back to Olympus for proper diagnostics and service sounds like there is a electronic fault in the lens zoom assembly which will most likely need to be replaced
4/3/2016 10:46:43 PM • Olympus SP-550... • Answered on Apr 03, 2016
Why won't my camera take a picture on automatic
Try resetting your camera to factory default options as a first step.
12/16/2014 1:14:11 AM • Olympus SP-550... • Answered on Dec 16, 2014
Can the battery case cover of an Olympus SP550 uz be easily obtained & easily replaced?
The cover on the camera is cracked or the battery case is cracked. If it is the battery that is cracked replace it immediately. If its the camera attachment that is cracked Gorilla Tape works wonders :) DO NOT USE THE PHONE IF THE BATTERY CASE IS CRACKED!
9/13/2014 6:22:57 AM • Olympus SP-550... • Answered on Sep 13, 2014
Image sensor
If the problem is dust, you can try to blow it away. Else, take the camera to a repair shop, the sensor is very sensitive and can easily be destroyed... Good luck! :)
4/17/2014 6:07:57 AM • Olympus SP-550... • Answered on Apr 17, 2014
Photos stored in one photo file. How do I extract them?
Recovering xD data is always tricky as the specifications have never been publicly available, it's only during the last couple of years that reverse-engineering has produced software able to do so.
I've found that there are plenty of recovery tools which can recover the raw data but very few which can actually make sense of it. I'd suggest that you first see if there's a money back option on CardRecovery and then try a free trial of Acute Tools PhotoNose ( http://www.acutetools.com/photonose/xd-card-recovery.aspx ). I haven't had the chance to try it for myself yet but I've heard from a couple of friends that it does work. F Recovery xD has also been recommended to me but again I have yet to try it for myself. ( http://www.filerecoverytools.com/products/fr_xd-picture/ )
What is certain at the present time is that there are no reliable free xD recovery tools, so whatever else you buy ensure that it either has a free trial or a money back option.
I hope that you have found my posting to be useful and ask in return only that you remember to rate my answer.
4/15/2014 9:25:15 AM • Olympus SP-550... • Answered on Apr 15, 2014
Restore software
Hi, what kind of situation you've met? Physical problem or data loss problem? If you meet physical problem, go to the repair shop is the best choice for you. If you meet the data loss problem, actually you can take out your memory and try some third-party data recovery tools to help you a lot. You can check this post to see if it can help you or not: http://www.uflysoft.net/data-recovery/data-recovery-for-win/
3/10/2014 4:51:37 AM • Olympus SP-550... • Answered on Mar 10, 2014
I was using kodak easy share to download my pictures and now that it is no longer i need to know how to use the share button
You still can use easy share. (I still have it) The share button, you use on the camera, to mark a picture you want to share. With the button, you tag the picture, you then later can share in the Kodak community. Not sure that still exists Check out on http://kodak.photonet.com
2/16/2014 10:02:56 PM • Olympus SP-550... • Answered on Feb 16, 2014
How do you restore software
You need the usb cable and have to get the software from Olympus's site
1/14/2014 11:23:26 PM • Olympus SP-550... • Answered on Jan 14, 2014
How do I delete all pictures from my camera?
The easiest way is to format the memory, either the internal memory or the memory card, depending on where those pictures are. Or both, of course. See page 39 of this manual: http://www.olympusamerica.com/files/oima_cckb/SP-550UZ_Instruction_Manual_EN.pdf
7/30/2013 8:08:43 PM • Olympus SP-550... • Answered on Jul 30, 2013
2answers
How do I remove the Olympus SP550UZ backpanel ? I
The viewfinder hides a little screw under the regulation ring. You can see on it a black circular cover, that is simply glued. Remove it and all will come out.
Vic
3/29/2013 2:38:14 AM • Olympus SP-550... • Answered on Mar 29, 2013
Olympus SP-550 UZ Digital Camera Logo
119 questions posted
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
Olympus Cameras
  • Olympus Cameras
Most Popular Question
delete all pictures from camera
  • Cameras
