20 Most Recent Dopod 838 Smartphone Questions & Answers
Storage memory critically low
You will have to delete some files to make room for the programs to work properly. If this phone supports memory card, you can move some files to that and free up the memory.
12/2/2017 6:29:20 AM • Dopod 838... • Answered on Dec 02, 2017
2answers
Cingular 8125 / dopod 838 problem
I Lost my IEEE 802.11 adaptor in my dopod 838 classic. please help me
3/3/2011 2:15:31 PM • Dopod 838... • Answered on Mar 03, 2011
I have a dopod 8383 pro on which the screen froze.
hi there can you send me how to set my dopod t8388 language to english. since i have this device it was set to chinese language...
1/21/2011 8:07:42 AM • Dopod 838... • Answered on Jan 21, 2011
Restoring factory settings
You can contact the service provider....
1/17/2011 4:43:20 PM • Dopod 838... • Answered on Jan 17, 2011
2answers
Dopod 838 pro manual
go to
http://www.dopodasia.com/Dopod/Singapore/En/Products/PDAPhone/838
sign up and you can down load verios manuals for dopod products
8/29/2010 12:21:12 AM • Dopod 838... • Answered on Aug 29, 2010
Hello, The screen of my Dopod
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying anything and you will need to keep trying before it can try pick.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Good luck.
6/21/2010 3:58:15 AM • Dopod 838... • Answered on Jun 21, 2010
I cant hear anyone when they ring unless i have it
The first thing that you can try here since the phone is not working fine and you can only hear the person on the other line when on speaker phone is to do a reset to factory settings on it, you can usually find that option under the Settings Menu of your phone and then once you find that check if the phone is working fine already.
5/17/2010 8:09:22 AM • Dopod 838... • Answered on May 17, 2010
Dopod 838 Pro Window Mobile 6.5 user manual.
Please download the dopod 838 manual from the below link:
http://www.htc.com/sea/userguide.aspx?p_id=37
Hope this helps.
Regards
Anand
5/6/2010 2:27:47 AM • Dopod 838... • Answered on May 06, 2010
Driver for Dopod 838?
yesssss
4/9/2010 2:36:43 PM • Dopod 838... • Answered on Apr 09, 2010
How to install themes
just copy .tsk file to my documents of dopod and then click on it and it will open today.just click ok.
3/24/2010 8:55:13 AM • Dopod 838... • Answered on Mar 24, 2010
Have a Dopod 838 smartphone. Trying to get it to
try uninstalling and reinstalling software
3/23/2010 12:44:07 PM • Dopod 838... • Answered on Mar 23, 2010
Does replacing the battery erase memory?
nope.bt dun leave it for too long.
3/21/2010 4:03:21 PM • Dopod 838... • Answered on Mar 21, 2010
IS THERE A RADIO IN THIS MODEL
According to the review at CNet http://www.cnet.com.au/dopod-838-pro-339271177.htm , built-in radio is not one of the features.
3/5/2010 9:38:57 PM • Dopod 838... • Answered on Mar 05, 2010
tip
Phone won't charge at all? No lights? Fix it here!
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Oct 10, 2009 • Dopod 838 Smartphone
I have been told I need a replacement mother board
I don't think its worth it, buy a new phone.
9/5/2009 2:38:37 PM • Dopod 838... • Answered on Sep 05, 2009
3answers
White screen
the same thing happend to me but if ixed it
what you do is go to the shops and buy and small screw driver and on the back of the slidyout bit there is two screws tighten them up a bit and that fixes the prob
8/10/2009 11:42:01 AM • Dopod 838... • Answered on Aug 10, 2009
Synchronizing
Can some1 give me a User guide for Dopod 838, pls
4/13/2009 11:23:04 AM • Dopod 838... • Answered on Apr 13, 2009
I cant accept any bluetooth for my dopodo 838 pro.
remember to set the bluetooth device properties visible to other devices and just turn the bluetooth on u know where it is in windows , then prepare a link by ur laptop or pc switch on the laptop bluetooth and then also set visible to other devices in properties and then try to send any file thru right click and then try to search for devices from laptop when u find dopod 838 try to connect for pairing use just 0 on both sides and finish sending thats it
2/21/2009 11:24:41 AM • Dopod 838... • Answered on Feb 21, 2009
It wont turn on anymore.I charged it,it turned on once & off agai
If your phone is older than a year or two, the battery pack probably is dying. I advise shopping well for a replacement or buying a new phone; one of our family had a simple phone only a little over a year old and Radio Shack (not my favorite source for anything) had the pack at $50 US. We didn't buy it as the phone cost only $30.  The next day, he replaced the whole phone for $20.
2/5/2009 5:45:03 PM • Dopod 838... • Answered on Feb 05, 2009
Dopod 838 Smartphone Logo
Popular Tags
46 questions posted
Popular Products
Top Dopod Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Dopod Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Dopod Computers & Internet
Most Popular Question
dopod m700 usb drivers
  • Computers & Internet
