20 Most Recent
ViewSonic N2060w 20 in. LCD Television Questions & Answers
How do I get the volume to work on my sky remote control?
I've just done this, guided by SKY but all you really need to do it....
Press Interactive button on remote
Choose option 5
Then choose set remote control, it should give you instructions and the correct cde fo ryou specifc tv
Good luck
x
Retuning ViewSonic N2060W
This set only supports Analog transmission. Digital transmission is not supported.You need a seperate Set Top Box to solve your problem.
I have a Viewsonic N2060w-1M TV but I don't have a
For the remote
codes, Viewsonic does not have any since the universal remote comes
furnished with a code book from the "MAKER" of that Universal Remote. I
have heard that the Philips TV brand codes for universal remotes work on
quite a few series' of Viewsonic TV's, so try those from your code
book.
Grey blotches on screen
sounds like your pixels are dying, there's really not much to doo other than have professionals looking at it.
Sky code
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0093
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Sky code
Sky remote codes: 0805 1783 1785.
Here are some other codes that may work with the Viewsonic: 1295 1694 1697 1800
Power lock enable
To get rid of the power button enable you need to either press and hold the power button on the tv ( not on the remote control pad) for approx 15 seconds or if that does not work do the same using the source button
