20 Most Recent
Dopod 818 Pro Smartphone Questions & Answers
Sound
cannot hear any sound whenever i receive any messages or my phone ring if all the sound notifications are properly set. thanks......
How to solve my 818 mobile phone will not switch on although direct with cable charged
1.Check the device's battery level for at least two bars of strength. 2.If the battery level is low, charge the battery. 3.If the issue is not resolved, remove the back cover. 4.Remove the battery. 5.Wait 10 seconds. 6.Press and hold the W key. 7.While pressing down the W key, re-insert the battery. •The device restarts and after approximately 15 seconds, the 'Recovery' screen appears•Release the power button but *continue holding the home button*, for another 30 seconds.StepThanks
My dopod 818 pro gets hanged on start up at htc
do a hard reset, beware all data will be lost and you need to calibrate screen again.
press two soft keys above call and end button press power button and insert stylus in reset hole,
phone will display some thing press green send button to restore or format.
you are done
HOW TO SET MY GPRS IN MY DOPOD818
You have to contact your network provider's customer care. They will give you the free gprs settings for your phone to access internet on your phone as well as on your PC using phone as a modem.
Hope this will help......cheers:)
MY DOPOD HAVE NO RINGING
hey hi........
thats so sad to hear,the problem lies with the speaker inbuilt.....
the only option is to replace ur speakers which cocts some 2 $ .....
thank you..take care.....
My touch screen is not
Possible fault within the display unit interrface to the main board.
The best is to try to remove any traces of moisture on the board , then reset to try . if not the panel is faulty
Theme, games and wifi
are downloading straight to cell (you need a data plan from your
carrier, go to download and games) this will cost $ depending the size
of theme/games and time it takes to complete.....okay #2 this way is
using a laptop/pc you will need a usb cable (to fit pc) to a mini usb
(compatible to your cell), go to site you wish to download game / theme
download to pc........then connect cell to pc via usb go to my computer
open cell...copy / paste (make sure any games downloaded is placed in
the games folder on cell, themes placed in themes..
try this site also
I have vodophone gprs in my number but how to
To activate GPRS in your mobile, first you need to get GPRS setting from vodafone. You can get those setting either by calling customer care or send SMS by writing 'GPRS' and send to customer care number.
When you will get GPRS setting save them as default stetting. After few hours you are able to access GPRS on your Phone.
cheers
