20 Most Recent
ZVOX ZBase 580 Questions & Answers
THE SOUND WORKS ON TV BUT THE REMOTE CONTROL DOES NOTHING.
Batteries could be bad, circuit board in the remote may be shot and try cleaning the infrared light on the remote and TV. If none of that works order a new remote or get an all in one, just make sure it has the programmable code for your TV
Why do we have no sound when everything is corrected properly?
test the speaker with a known good source (cell phone, other stereo, etc) and see if that works. You have to pinpoint the reason why it's not working, could be power, could be signal source, could be connection quality, could be poor internal connection or solder/joint on a wire
We lost power and now zvox volume very low
You could have fried something through a power surge or a connection came loose. Check all wiring and see if the speakers are connected, try different audio signals to see if that helps
Zvox remote not working
Place the unit in learn mode: http://www.zvoxaudio.com/mas_assets/theme/zvoxnew/documents/ZVOX580_LearnRemote_Guide.pdf
No sound
What type of cable are you using to connect your ZVOX system? Are you connecting your system directly to your TV? In order to solve your issue as quickly as possible I would encourage you to call our toll free number. (866) 367-9869 We can troubleshoot over the phone and get you up and running in no time. Thanks.- JoeZVOX Audio - Great Sound, Made Simple
www.zvoxaudio.com
866-367-9869
