20 Most Recent
Amana ARB1917CSR Bottom Freezer Refrigerator Questions & Answers
How do I replace my freezer light
An owners manual I found online says:
Freezer
- Pinch rear tabs on light cover and pull straight down.
- Remove light bulb.
- Replace bulb with appliance bulb no greater than 40 watts.
- Insert front tabs of light cover into freezer liner and snap rear portion over light assembly until rear tabs engage.
The manual illustrates the bulb is behind a plastic grille right by the temperature control knob.
Amana ARB1917CSR ? Refrigerator freezing food, (bottom) freezer working OK
I picked up on something you wrote within your problem description. "got the thermostat replaced under warranty" & "that worked for a while ". back in Aug of 2002. It's August of 2008 and your thermostat may have failed again. 6 years later... not so unusual. Anyway, since your fridge has a bottom freezer, there must be a pass thru between the freezer and the fridge compartment in an area you haven't examined yet. The fridge gets cold air delivered from the freezer to keep it cold thru this pass thru and many fridges have an adjustable flap that allows you to limit that cold air flow. Time permitting, can you do a more thorough examination of the fridge area ( side walls near crisper drawers perhaps?) or better than that, remove the drawers and look for that air duct pass thru. Once located, if it does not have an adjustable damper, try a little duct tape to limit the amount of cold air from migrating into the fridge compartment. Other options: Can you contact Amana customer support directly and get their support? That particular model has been discontinued by Amana but they should be able to support it. Not sure I added anything to what you already know. Gave it a shot thou...
Can the door swing be changed?
Yes the door can be changed to open from the opposite side, there are removal plugs that need to be removed from the opposite side and just change all the hardware from one side to the other, change the middle hinge first and put on the bottom door first, after its is mounted you can put the bottom part of the top door on the hinge and last the top hinge, and just make a few minor adjustments.
The refrigerator often freeze food
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
Many times a freezer and/or refrigerator
do not work right because of a dirty condenser coil...there are also many other
things that can go wrong.
If you are hearing a clicking or buzzing then check out the
last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start
trouble shooting your unit...and something that you can do rather then calling
a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
