Wi-Fi provides wireless Internet access over distances of up to 100 meters (00 feet).
To use Wi-Fi on your phone, you need access to a wireless access point or "hotspot". The availability
and range of the Wi-Fi signal depends on the number, infrastructure, and other objects
through which the signal passes.
Turning Wi-Fi on and connecting to a wireless network
From the Home screen, press MENU, and then tap Settings > Wireless & networks.
Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless
networks.
Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks
are displayed in the Wi-Fi networks section.
If the wireless network you want to connect to is not in the list of detected networks,
scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network
settings, and then tap Save.
Tap the Wi-Fi network you want to connect to.
If you selected an open network, you will be automatically connected to the network.
If you selected a network that is secured with WEP, enter the key and then tap
Connect.
Depending on the network type and its security settings, you may also need to enter more information
or choose a security certificate.
When your phone is connected to a wireless network, the Wi-Fi icon appears in the
status bar and tells you the approximate signal strength (number of bands that light up).
The next time your phone connects to a previously accessed secured wireless network, you
will not be prompted to enter the key or other security information again, unless you reset
your phone to its factory default settings.
Sometimes the earpiece plugs up with dirt/dust, which could potentially block enough sound that you can't hear anything through it (my HTC OneX+ is doing this, and I've been using the speaker-phone on it for months now. Someday I'll take it apart and clean it... someday...) You could try removing the casing and other components to get at the speaker and clean it up.
Your phone's earpiece could also be non-functional. I'm not sure about this particular model, but as with many HTC phones, the little earpiece speaker can usually be replaced. The hard part is actually getting to it...
You can usually do a hard factory reset by: powering off the phone, removing and replacing the battery (if possible), then holding the volume down button while pressing the power button. A screen should appear where you will then highlight "factory reset" (or similar) and the phone should restart without any lockscreen to contend with.
browse the HTC website and navigate to download section from there download and install HTC sync manager for HTC Wildfire relevant to your Operating System. The Sync Manager suite include the required drivers so you do not have to install them seprately as HTC provides them in a bundle.
Only Telus can unlock it and only if the rent to own contract is paid off. If you take it to a third party unlocker, Telus can still lock it on you by using the IMEI number.I would urge you to edit out your IMEI number as it can allow the unscrupulous to clone your phone and make calls at your expense.
iPubsoft Studio recently announced that it released its new software -- iPubsoft Android SMS+Contact Recovery for Android program, a new program that helps HTC users retrieve lost message from HTC device, The program includes significant improvements like simplified operation optimization, can scan text message, contacts file.
Simple Tricks to Retrieve Deleted SMS Messages from HTC Phones
You can try GT Recovery for Windows!
GT Recovery for Windows is a professional data recovery for Android phone or tablet. It can restore deleted photos,videos,audios,documents from Android SD card and internal memory. Whenever you lost important pictures or deleted photos by accident, you can use it to scan and recover the images on your Android devices.
Here are the steps to recover deleted data on Samsung Galaxy S4.
With this way you can recover deleted data on any brands of Android device such as Samsung, HTC, Huawei, Sony, Motorola, Lenovo, LG, Sharp, etc.
Google+:https://plus.google.com/communities/109657948177651590858
Facebook homepage:https://www.facebook.com/GT-Recovery-for-Windows-527139864132104/
Download Link:http://www.gtrecovery.net/
