20 Most Recent
ASUS P5P800-MX Motherboard Questions & Answers
I have asus p5p800-mx mother board morboard
Have you tested the monitor to see if it is working? Is the vga cable good? Are you getting the BIOS start-up display screens when computer is booting up or no display at all? It is odd that both the on board video and video card would be bad I would double check the cable connection and the monitor. If the cable is good and the monitor is working properly than the board might be bad. You should at least get the BIOS start-up screen display.
Display driver
Try the ASUS website, support section. As do the rest of us.
Mothererboar driver841
Hello the driver can be downloaded here:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5P800-MX&p=1&s=22If it is a asus mainboard.Select first your windows system.Next open the driver folder, and click on global for download.Unzip the file before you install the driver.Other files can be found here at intel:https://downloadcenter.intel.com/default.aspxBy running the update utility.Or visit the mainboards manufactures homepage.Good luck finding the driver.
No sound control
if your computer came with a motherboard disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or
control panel,administrive tools,computer management,device manager,sound video and game controllers could be a yellow question mark? right click to re-install drivers
control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Freezing up windows blosks program claiming a
Sounds like malware
Try running Malwarebytes free version from a usb
drive if possible. Once you download it onto the
drive rename it from MBAM.exe to winlogon.exe (a
virus may be the problem and no virus will look
twice at winlogon as it is a system process), then
boot to safe mode and send malwarebytes to desktop
(create shortcut), install update and run full
scan.Follow instructions for getting rid of
malware.
http://www.malwarebytes.org/
If you need anti-virus software and firewall, you can get decent freeware here:
http://www.zonealarm.com/security/en-us/zonealarm-pc-security-free-firewall.htm
http://www.avast.com/free-antivirus-download
Realtime protection. Good luck
If this helps you resolve your problem, please
consider giving me a good rating and a quick
thanks or good job.It will help me as well.
Thank you.
MY COMPUTER HAS NO AUDIO DEVICE I SEARCHED ON THE
mcdevito75 here, Most Computers (Desktop) have built in Audio devices but you"ll need outside speakers, and you have to mke sure the audio is on in your computer. ----- Try this, in your computer click on start, then Control Panel, then on audio speakers devices, then un--check the MUTE box and Check the Place icon in the task bar box. Then hook up speakers to your computer, speakers available at Staples, Radipo shack etc.
ASUS P5P800 Motherboard no video
Oh what a shame, what would you like me to do? I'm not going to give you a video and I don't think Blockbusters do them any more.
Perhaps you would like to rephrase your post.
Computer powers up and then
That could be RAM memory issue.
Also make sure *********** board is not ground with cabinet.
Make sure your amps power supply unit is working fine.It is square box on top of cpu cabinet.
Change RAM memory if your power supply is working fine.
Clean dust from all parts.Open processor and its fan then clean dust from it and reattach into it's position.
Let me know if you need further assistance.
Thanks for using FixYa.
