20 Most Recent Brother MFC-J415W Multifunction Inkjet Printer Questions & Answers
2answers
How to fix Brother printer J415W with error message "Unable to Print 4F
The printing process is blocked by a system problem, indicating the Brother Printer In Error State Windows 10. Normally, this problem is caused by system permission settings, corrupted drivers, or system conflicts. Solutions of Brother Printer In Error State Windows 10:- 1. Make ports settings changes. 2. Make sure that your printer is Online. 3. Reinstall the printer driver. 4. Set the Print Spooler service to automatic. 5. Update Windows. If the problem continues, check this blog or call Printer Support to stop more printer damage. Solution with Expert Advice- Brother Printer In Error State Windows 10 fixed-brother-printer-in-error-state-windows-10-1200x676-undefined-undefined-0_0.jpg
8/31/2020 9:44:18 AM • Brother... • Answered on Aug 31, 2020
How to fix Error message ..Unable to init.4F ?
Sorry... Print head damaged. There is an very low possibility to erase the error without buying new print head, but it's unprofitable
8/23/2017 7:26:23 AM • Brother... • Answered on Aug 23, 2017
2answers
Does brother mfc-j4410dw make routine cleans? How can i install a ink dispenser?
I had a Brother MFC that would startle me when it starts to perform its maintenance work. I never bothered asking myself where the ink went.
8/8/2017 10:31:42 AM • Brother... • Answered on Aug 08, 2017
Fehler:Init.4F
defective scanner
9/7/2016 3:44:27 AM • Brother... • Answered on Sep 07, 2016
Why am I unable to init 48?
This message indicates a problem with the Waste Ink Tank. To correct this it will require dismantling and cleaning then resetting the internal counters on the machine. Consider replacing the machine unless you want to do the work yourself. The costs in doing this work on an Inkjet Machine generally are more than a replacement printer.
4/1/2016 2:01:36 AM • Brother... • Answered on Apr 01, 2016
Unable initialize 94 printer Brother MFC-J6920DW
There is no such error. please confirm
2/4/2015 6:49:33 AM • Brother... • Answered on Feb 04, 2015
Tintenabsorber full, how can i slove the problem schaffen?
you need to replace them
1/21/2015 5:10:51 PM • Brother... • Answered on Jan 21, 2015
0answers
Unable to init 4f
Be the first to answer 8/12/2014 6:21:54 PM • Brother... • Posted on Aug 12, 2014Be the first to answer
Unable to Init. 4F
Sorry but there's no proper solution for it, besides changing printhead or an miracle. both solutions are unprofitable
6/5/2014 9:21:11 AM • Brother... • Answered on Jun 05, 2014
0answers
Como deshabilito el informe de impresion de brother mfc-j1010dw
Question edited and translated to English. We are a North American website, we only speak English. You can't https://www.google.com/search?q=Brother+MFC-J1010DW+%22disable%22+print+report ..
3/23/2024 1:39:34 AM • Brother Office... • Answered on Mar 23, 2024
Brother MFC-J985DW Colour Inkjet Multifunction Printer. Why doesn't the paper jam message go away?
Question edited for clarity. 985 or 895? Usually because the jam hasn't been cleared or the machine hasn't been reset. Remove the paper tray an open the cartridge bay. Open the rear paper door, check underneath. This machine has a lot of paper scraps in it. :>D
3/17/2024 12:10:58 AM • Brother Office... • Answered on Mar 17, 2024
How Do I Fix Brother Scanner Error Code 2023?
https://help.brother-usa.com/app/answers/detail/a_id/74629/~/error-2023---usb-communication-error "Error 2023 - USB Communication Error" This typically indicates a communication error between the Brother machine and the computer. 1. Turn off the Brother machine, wait 15 seconds and then turn the machine back on. 2. Attempt to scan again. - If you're able to scan, then the issue is resolved. - If you still receive the error, go to step 3. Warranty Calculator to check the status of your machine's warranty. If your machine is out of warranty, we offer a repair option. Please contact Customer Service for warranty or repair options. - If the USB port appears undamaged, go to step 5. step 8. here for instructions. 9. Download and reinstall the Scanner driver, which includes the DSmobileCapture software. Click here for instructions. Don't reinstall using the DVD. Instead download the latest version of the software from http://support.brother.com. 10. Attempt to scan again. - If you're able to scan, then the issue is resolved. - If you still receive the error, then the issue is likely caused by a software conflict. If you have another computer, try installing your machine on that computer and scanning. This will determine if there is a problem with this computer. If after troubleshooting you are still unable to scan, contact your computer manufacturer for additional support.
2/20/2024 2:59:01 AM • Brother Office... • Answered on Feb 20, 2024
What does a poor line condition error mean
These errors are usually related to interference, static, or noise on your phone line. Here are some steps to troubleshoot and resolve the issue: Check for a dial tone: 1. Press the Hook button on your Brother Intellifax 2820 and listen for a dial tone. If there is no dial tone, press Hook again and proceed to step 2. If there is a dial tone, press Hook again and move to step 4. 2. Verify telephone cord/line connection: Ensure that your telephone cord/line is correctly connected to the port labeled LINE on your machine (located on the lower left side). If the cord is already in the LINE port, proceed to step 3. If it's connected to EXT, remove it from there and connect it to the LINE port. Press Hook and check for a dial tone. If still no dial tone, proceed to step 3. If there's a dial tone now, move to step 4. 3. Test with a known working telephone: Disconnect the telephone cord/line from the LINE port on your machine. Connect it to a known working telephone and test for a dial tone. If there's no dial tone, the issue is related to the telephone line or wall jack. Contact your telephone service provider. If there's a dial tone, reconnect the cord/line to the LINE port on your machine. Press Hook and check for a dial tone. If still no dial tone, consider warranty and service options. If there's a dial tone, proceed to step 4. 4. Remove splitters or other devices: Check if you have any splitters, commshare devices, credit card machines, or power strips connected to your machine or the telephone wall jack. If yes, remove them for testing purposes. After removing any devices, continue to step 5. 5. Adjust Compatibility settings: Press Menu/Set. Navigate to Miscellaneous > Compatibility. Choose Basic (for VoIP). Press Menu/Set and then Stop/Exit. 6. Send a fax: Insert the document face down in the Automatic Document Feeder (ADF). Adjust paper guides to fit the width of your document. Enter the fax number using the dial pad. Press Fax Start. Remember that testing the Brother machine on a different, known-working telephone line can help determine if the issue is related to the machine or the telephone line. If the problem persists, consider contacting Brother Customer Service for further assistance. If you feel the need to seek another machine, assess the features you need and your budget. Here are possibilities: here are some reputable brands and their models to consider: Epson WorkForce WF-2750DWF: This all-in-one printer and fax machine offers economical ink usage and a convenient LCD screen. Features: Print, copy, scan, and fax. Scan resolution: 1200 x 2400 dpi. Dimensions: 16.73 x 14.17 x 9.06 inches. Weight: 14.55 lb. It's a budget-friendly choice for home and office use. Brother MFC-L6800DWT: A high-speed monochrome laser fax machine with additional features like printing and scanning. Ideal for small offices. Check out its performance and ease of setup. Canon TR8620: A multifunctional all-in-one printer, copier, and fax machine. Offers versatility and functionality for various tasks. Consider it if you need a reliable fax solution
2/15/2024 2:09:59 AM • Brother Office... • Answered on Feb 15, 2024
Brother HL-L2340DW toner reset counter had brother HL-2040D and was able to reset toner counter
1-877-BROTHER (877-276-8437) M-F, 9:00am to 9:00pm Eastern Time
1/17/2024 5:05:45 AM • Brother Office... • Answered on Jan 17, 2024
2answers
Repair a Brother Printer MFC 235C
Depends what is wrong with it.
1/8/2024 2:00:28 PM • Brother Office... • Answered on Jan 08, 2024
Brother MFC-J415W Multifunction Inkjet Printer Logo
29 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
  • Brother Office Equipment & Supplies
Most Popular Question
unable init 4f
  • Office Equipment & Supplies
