20 Most Recent
Brother SE400 Computerized Embroidery and Sewing Machine Questions & Answers
Touchpad will not work
www.overstock.com > ... > Sewing Machines
Overstock.com
Rating: 4.7 - β16 votes - β$359.97 - βIn stock
With a touch pad operational panel and LED screen controls, the Brother Project Runway ..... How to Troubleshoot Your Sewing Machine from Overstock.com.
How to transfer embroidery patterns to Brother sewing/embroidery machine
Machine designs first designator is the file name. Your machine shows the file number for the design you want. You do still need to "select" that design number shown to actually begin teh file transfer from a thumb drive or cable direct from your computer if your machine has that feature.
Cheers,
Kelly
Embroidery Services
San Diego, CA
What does this error message mean?
Dear BreeAnn,
I would reboot the machine. That means. Turn it off pull the plug and restart or cold Boot Strap. Further open your manual and look for a factory reset. Remove the disc if it came with one and reinstall it.
Save all your creations to file if special programs are developed before the new startup. Manually assist the machine through a hand cycle. Moreover, check to see if all the e-stops are satisfied. That means switches stuck open or closed.
Blow out dust from working areas. It appears from a remote view. Having worked fine. It is a matter of oversight. I hope you get back into creating soon.
The rest of the links are search sites. If you become stumped.
Here is the most direct answer I can find for you. Become a member and place you direct information into the link after reading the reflection.
What is F06 Np Sensor Break on Baby Lock Sewing Machine Yahoo Answers
Here is an E HOW site others are drawn too for answers on that subject as well to expand an accomplishable solution.
Troubleshooting Brother Sewing Machine eHow
Here is another member offering contact sources and a direction on procedure on our network.
F06 np sensor break on brother se400
They are general links. I recommend tech support directly with a talk through. The information should reside in the manual. Fare. Well.
