20 Most Recent Dell Dimension 4400 Power Supply ** FREE ** (DE4400300WB) Power Supply Questions & Answers
3answers
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
2/3/2018 11:58:39 PM • Dell Dimension... • Answered on Feb 03, 2018
2answers
Computer acts like it in
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this will help don
8/30/2011 3:17:07 PM • Dell Dimension... • Answered on Aug 30, 2011
Dell Dimension 4400 NEVER froze
You need a power supply! Go to Amazon and search for one that is the same specs as yours. Fairly easy to replace, don't use your old one anymore, it could be dangerous.
5/5/2011 7:22:52 PM • Dell Dimension... • Answered on May 05, 2011
Dimension 4400 won't boot and
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
2/5/2011 7:54:58 PM • Dell Dimension... • Answered on Feb 05, 2011
Dell Dimension 4400 will not
If you have a volt meter, check the P1 P2 etc...power output. Sound like you power supply may be corrupt.
1/12/2011 10:50:56 PM • Dell Dimension... • Answered on Jan 12, 2011
2answers
Dell 4400 Main power in house
The power supply or mother board probably went out. Did any other items in the house stop working? This happened to me years ago and the electric company reimbursed me for damages.
You can try unplugging the power cord for a few minutes, then retry listen for any beeps from the computer. If it is powering on but nothing on the screen and no beeps *********** board is probably toast.
12/10/2010 9:22:16 PM • Dell Dimension... • Answered on Dec 10, 2010
Dimension 4400 Power Supply ** FREE ** (DE4400300WB) Power Supply: My Dell Dimension 4400 is dead with none of the 4 ...
It seems like it that you have a faulty power supply. Also the motherboard may be damged aswell, But most probably you can fix your PC by changing the power supply.
5/19/2010 8:36:19 AM • Dell Dimension... • Answered on May 19, 2010
Computer doesn't come on.
Easy check is: power the system off. Unplug the power supply from the outlet. Hold the power on button in for at least 10 seconds. Remove the CMOS battery. Reconnect the power supply to power. Attempt to power up. See what happens. If it comes up and asks for you to set config, power down, unplug the power supply and hold the power on button for 10 secs. Replace the CMOS battery with a new one (CR2032 button battery...about $5 for 2 in the Wal-Mart photo dept) and power on. The reason for the repetition is to reset the BIOS.
1/22/2010 1:58:20 AM • Dell Dimension... • Answered on Jan 22, 2010
Push button small light in middle comes on fan on
i have this problem with my E Machines W 3104 and i unplugged it and still i could make the fans turn on like you said for maybe a quarter turn, plus the lights would basically flash once every time i pressed the power button. after the little death beep noise from inside when it loses power completely i plug it in again and it will turn on just fine . the first time it did that i thought it was because it had too much power built up in the power supply, and maybe it did but it ussually turns right back on after "draining it". try that and see if it helps at all
11/25/2009 9:24:13 PM • Dell Dimension... • Answered on Nov 25, 2009
Dell 4400 won't power up Flea light works
For non-BIOS issues:
If you did not try to update BIOS before the problem started then try these troubleshooting steps.
1. Full power down. Unplug the power cord from the Power supply. Then hold down the pc power button (this discharges any residual power in the capacitors).
2. Open the case and reseat the graphics card, hard drive, and RAM.
3. Take out one of the RAM sticks if there is 2 or more. Swap the RAM sticks in different RAM slots. Try one stick at a time to see if you can get the PC to boot. If this works, then the remaining ram sticks are damaged.
4. Set the Cmos jumper to clear. Power up the pc. Power down the PC. Set the Cmos jumper back to normal position, power up the PC.
5. Unplug and replug all the power supply cables.
6. Check the powersupply function. Either by a powersupply voltage checker (20-25 dollars at local PC shop), get the supply tested at a PC shop (usually a free service), put the powersupply in a different pc, or try a different powersupply in the problem computer.
If the Powersupply checks out ok, then you will have to do a process of elimination to find out what part or parts are the culprit of the No-Boot.
Start by pulling all the ram sticks if you have not already. This is the easiest components to check and usually a culprit.
If it is not the RAM, you have to continue removing items such as sound cards, un-plugging hard drives and optical drives, other PCI cards. Do this one at a time until you find the culprit. If a POST screen, meaning you can see Anything from the PC brand name to Motherboard brand name appearing on the screen. The PC may not boot to windows, but it Does post at this point, and with that the problem is resolved. If windows does not load, then you have a new problem. Best dealt with asking a new question.
Brian
7/6/2009 11:57:54 PM • Dell Dimension... • Answered on Jul 06, 2009
2answers
Dell 4400 won't power up,Flea lightworks, battey
your motherboard BIOS seems to be corrupted ..pls replace the motherboard..
6/29/2009 10:04:28 PM • Dell Dimension... • Answered on Jun 29, 2009
2answers
I want to know about some adventures video games?
Check out Big Fish Games. It is a subscription service but they have all types of games including adventure and hidden object. You can also tryp Pogo since they have both a fee and subscription service. Last, but not least, you can try one of your local computer stores or the electronics section of "big box" stores like Target, Walmart, Kmart, etc.
4/19/2024 6:52:18 PM • Dell Computers &... • Answered on Apr 19, 2024
3answers
Dell Latitude won't connect to internet. Windows XP.
It is too old, plus XP is a virus magnet and has been unsupported by Microsoft for nearly 15 years. Mainstream support for Windows XP ended on April 14, 2009. Windows 7 and 8 have passed you by, Windows 10 is current and Windows 11 awaits. https://www.google.com/search?q=Dell+Latitude+won%27t+connect+to+internet.+Windows+XP ..
4/19/2024 3:11:57 PM • Dell Computers &... • Answered on Apr 19, 2024
2answers
Where can I get a replacement adapter cord for my Dell 3052 - 20" all in one model reg model W158?
Amazon, or if you only want the main lead, Walmart.
AC/DC Adapter For Dell Inspiron 20 Model 3052 20- ...
Amazon.ca https://www.amazon.ca > Adapter-Inspiron-20-3052-... AC/DC Adapter For Dell Inspiron 20 Model 3052 20-3052 W15B W15B002 All-in-One Desktop PC Power Supply Cord Cable PS Battery Charger Mains PSU : Amazon.ca: ... $26.27 · ‎ In stock ..
1/11/2024 6:55:07 AM • Dell Computers &... • Answered on Jan 11, 2024
My dell laptop i5 does not recognize the external ac source
I would try another power supply and plug that in.
1/5/2024 9:01:17 PM • Dell Computers &... • Answered on Jan 05, 2024
Where is the reset button on the dell inspiron 3052 tag c99f22
Try replacing the BIOS battery for access to the computer.
10/23/2023 4:58:31 AM • Dell Computers &... • Answered on Oct 23, 2023
Are there any other ways to bypass the log on screen on a dell inspiron 3052 so i can factory reset it
Windows can be accessed renaming two files. computingterror.blogspot.com/2014/03/hack-windows-7-login After that being done you should run the Support Assist OS Recovery from DELL dell.com/support/kbdoc/en-us/000177401/restore-your-system-using-dell-supportassist-os-recovery Windows 10 can renew itself, without Windows Setup on a USB medium.
10/23/2023 4:55:37 AM • Dell Computers &... • Answered on Oct 23, 2023
Dell Dimension 4400 Power Supply ** FREE ** (DE4400300WB) Power Supply Logo
13 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
  • Dell Computers & Internet
Most Popular Question
dimension 4400 boot
  • Computers & Internet
