20 Most Recent
ASUS PSU | A-45GA 450W RT (A45GA) Power Supply Questions & Answers
450W ATX SMPS of Intex
sir all smps can be reapired using indian jugar technique. first of all see twi diods under the burnt transistors check them they are short then check the capacitors if they are not leaky or pregnant then see bridge reactifier change all that looks short or open then replace all and the transistors with 13007 transistors(jugad) be careful that 13007 must be isolated from heat sink that means metal part must be fixed to them but not short to them . replace the fuse with 2 ampere fuse (for safety) ..... have fun
When power on , shorting in power starter stage
Check for dust build up static charge can jump on dust and cause a short. Keep it clean if powering down or just keep it on you will have less problems. That's why companies leave comp on startup cause shorts
Suddenly power failure ,when the
My advise to you is to never turn of your computer!
the constant start and stop put stress on your power supply not to mention dust build up and if not properly cleaned the startup process can cause a short which I've seen so many times.
I have a computer which is 8 years old I never wanted to turn it off but leaving for two weeks vacation I turn it off. On my return the startup it shorted yeah dust build up.I had to replace the power supply, still running now. (A warm drive is a happy drive)
Smps is not switched on
cheak the fuse of smps and cheak the rectifire diode of smps and also cheak driver transistorof driver tranformer
Power blinks
power adapter or battery has went bad replace them
HOW CAN WE SOLVE LOAD PROBLEM OF ATX SMPS
First, I am not very good with acronyms, so what is an ATX SMPS.
I have a feeling it is an ATX style Power Supply which cannot handle a load. What are we talking about per voltage rail and where do you think the drain comes from?
How do I enhance my Asus PadFone X mini speaker loudness?
Look for a program called Sound Booster or one called DFX. DFX is my favorite because it not only boosts the volume, but lets you add other effects to enhance you sound as well. There is a free version. but to get all the effects you have to upgrade to the paid. If audio is important to you, check it out.
How to fix sound is not working in my asus laptop?
Try going into sound select and test reinstall driver off Asus website..if you installed new windows or update drivers may not work right...see if you can roll back driver in device manager ..if not lookup your laptop model and reinstall...
