20 Most Recent
D-Link DI-624M Router (DI624MRE) Questions & Answers
I have a westell adsl2t
open a browser from a computer that is connected to the router (preferably wired) and in the address bar, enter http://192.168.0.1
the login is admin and the password is blank.
click WIRELESS on the left
you will then be on the wireless setup screen.
Enable the type of security you want, and the key or passphrase.
For instance, if you want something easy to remember, set the security to WEP and use your 10 digit phone number as the WEP key.
Change the SSID to something other than dlink while you're there.
That's all there is to it. Apply the changes and you're done!
D-Link DI-624M...
Answered
on Feb 28, 2011
Can't connect d-link D!-624 after having computer
Is it the only PC on your network that couldn't go online? If it is, then the drivers for the PCs network card may not be installed properly. Go to device manager to check if drivers were properly installed (Right-click My Computer-Properties-Hardware-Device Manager-Network Adapters).
D-Link DI-624M...
Answered
on Dec 17, 2010
I need the software to
If you cannot get a copy if the installation CD, then the D-Link wireless router can be configured manually.
Connect a LAN cable from the D-Link to the LAN port on your computer - open a browser and enter the D-Link's configuration URL.
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter)
You can now change the default password and configure the wireless settings eg. SSID and encryption etc.
To secure your wireless network from unauthorized access, please click on this link and follow mu instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
D-Link DI-624M...
Answered
on Dec 02, 2010
I have a Dlink routerand am able to connenct tothe
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router.
If you are still unable to access with above ip then press RESET button for 10 seconds then all settings defaults then you can access it.
Let me know if you need further assistance. Thanks for using FixYa.
D-Link DI-624M...
Answered
on Nov 11, 2010
I recently moved from Cable ISP to DSL ISP
The reason you have no internet is because the router is specifically for cable. your description contains errors what i think you mean is that you have gone from cable dsl to an adsl, correct me if i am wrong. Basically your modem connected to your router via an ethernet cable and then the router fed the wireless signal to your wireless devices or via ethernet through the 4 ports in the back. With adsl you have a feed from your phone line to an adsl modem so the only way for you to get the dsl router working is to have two ethernet leads connecting to your pc, one from the modem to the pc and one from the pc to the router. You would also need to setup internet sharing on the pc thats connected to both devices.
Either do it that way or buy an adsl router
D-Link DI-624M...
Answered
on Nov 11, 2010
My d-link router has lost its connection was
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
D-Link DI-624M...
Answered
on Jul 15, 2010
I have incoming connection, but WLAN from ports
There should be a reset button on the back of the device that will allow you to reset it to "Factory Default".
You will have to reconfigure the router for security once this is done.
If the router does not reset to factory, then I would replace the router all together. I had to do that for a client this morning.
Good luck
-Carlos:
D-Link DI-624M...
Answered
on Jan 07, 2010
Cant connect!
- Try to power cycle the Motorola modem and the router for 5 minutes.
- After 5, turn On first the modem, make sure all the lights of the modem are stable before plug in the router.
- If this procedure doesn't work then I suggest that you might need to update the firmware of your router.
D-Link DI-624M...
Answered
on Jul 04, 2009
I got my old D-Link Di624 out and reconnected. Now I need help!
On one of the computer that has connection to the router, type 192.168.0.1 in the browser's address bar. The router's config page will come up. Since you're going to be using this page a lot, you might want to bookmark the page for easy access.
On the config page, select "HOME" tab and then select "WIRELESS" on the left column. Find Authentication: WPA-PSK and select that. Provide a "passphrase" and make sure you confirm it. It can be any phrase you want to use. Check apply and you're done setting up the router.
Now you have to setup your computer's to match exactly the same authentication. you should see all the available network. Select default network and then click on configure. In the authentication pull down menu list, select WPA-PSK, then select "authentication config". When the advanced security settings comes up, in the WPA PASSPHRASE field, type the PASSPHRASE you used earlier in the router's config. Hit OK and that's it for that page.
Now go back to the utility page and find profile in the middle column. you should see a "default" profile. Select that and click on "connect" on the right column. If you see a circle on the small icon just to the left of default, then you've secured your computer.
Basically, whatever you do to the router's config, you have to do exactly the same to the NIC's utility page. If it fails and you have to restore default on the router, there's a small hole in the back of the router. Press a small pin into it for 10 seconds and it will restore the default setting, that is, no security of any kind.
Please rate this a fixya.
D-Link DI-624M...
Answered
on May 19, 2009
Cisco VPN not working
please call dlink tech support at 877-453-5465. just an advise on how to handle the call when you reach dlink tech support (agent); do not agree to call back after you troubleshoot with them (they'll be giving you a case id reference# and be advising you to check your pc or call "who" and call them back to continue the troubleshooting). insist to the agent that he need to resolve the problem asap (by the way, agents are not allowed to drop the call or they'll be dead-history!). and if the agent still insisted you to call back, ask for a "senior level technician" to finish the job (escalate the problem).
fyi: dlink tech support handling time to resolve a call is 15 to 18 minutes only. if you reach that 15-18 minutes (max) time the agent will think of a way for you to call back (advising you to check with your pc manufacturer, check with your ISP, call microsoft to update your software, etc... non-sense!) they need to do this in order to reach their handling time (agents need to reach 21 to 25 billable calls, and billable calls are "solution provided", "resolved", and "dropped call"). ---- believe me, i was one of them and repented.
D-Link DI-624M...
Answered
on Mar 14, 2009
Problem with wireless network!!
You don't need the CD no. What you need to do, is reset the router if the old wireless authentication key is still activated.
To do this, locate the little hole at the back of the router, and use a pen to press it in for approx 30 seconds. This will reset the router to it's default values, and allow you to configure the authentication and such yourself.
D-Link DI-624M...
Answered
on May 25, 2008
