20 Most Recent D-Link DPR1260 Rangebooster G Multifunction Print Server (790069283475) Print Server Questions & Answers
Adding another computer to my print server
I need more details on Brand Model and make of your print server please.
10/9/2017 5:48:57 PM • D-Link DPR1260... • Answered on Oct 09, 2017
3answers
Not a valid image file.
This sounds like something on the Hardware, on the way its uploading onto the computer. Does it do this with every image you try to scan onto PDF?
9/29/2017 7:59:29 PM • D-Link DPR1260... • Answered on Sep 29, 2017
Lights are dim on dpr-1260 printer server
You probably need to replace the AC adapter.
8/5/2014 5:17:31 AM • D-Link DPR1260... • Answered on Aug 05, 2014
Cannot access setup utilities in dpr-1260 print server.
Try to log in with "admin" as the P/W (without the quotes.
8/24/2010 8:05:30 PM • D-Link DPR1260... • Answered on Aug 24, 2010
2answers
I have a D-Link DPR-1260 print server. All of a
Try changing the configuration as follows:
Used a fixed IP to DPR instead DHCP
Put the name (dlink-fbd714) used by DPR in the windows’ host file
It will work again.
Please let me know if this does not help else please accept it.
Thank You for contacting Fixya.com
3/20/2010 2:08:33 AM • D-Link DPR1260... • Answered on Mar 20, 2010
I am trying to install to Win 7? Manual does not
Go to the official site of hardwaremanufacturer.Search for viable driver for yourPC.
12/24/2009 4:12:51 AM • D-Link DPR1260... • Answered on Dec 24, 2009
How to add my new laptop w/vista to the print server
Visit: http://www.linksysbycisco.com/US/en/support/WPSM54G/download to download the software called (driver) and install it using the Quick Installation right below it.
8/16/2009 8:12:07 PM • D-Link DPR1260... • Answered on Aug 16, 2009
Problem with DPR-1260
this kind of problem occurs in dlink router sometimes & after some time router stop responding after 10 -15 min & once u reboot the router it again start work for a while. the best solution to this problem is to reset the router back to its factory defualt settings u can do this by press the reset button on the back on the router ( it looks like a small hole u have to use a pin for press that button) once u have reset the router to factory default settings just reconfig the router & i am sure it will start working fine in case u still face the same problem just contact D-link or send me the details about the problem & the physical setup of ur router & printer etc
2/10/2009 8:08:48 AM • D-Link DPR1260... • Answered on Feb 10, 2009
I am trying to install D-LINK. have tried many times and failed.
Hi unioncharlie,
What you've done so far is fine, next connect the printer to the d-link with a wire, and allow the d-link to recongize the printer. Once that's done, you'll need to log into the d-link and get the IP address that it's assigned the printer. Then on your laptop, add a new printer and assign a new port using an IP address port, and put in the IP number you got from d-link, and the laptop should find it. Once that's all done, you can disconnect the wire from the printer to the d-link, and everything should still see each other. If not then you've got some settings either on the d-link or the laptop wrong. That printer acts just as a pass through for IP assignment.
Good Luck,
Mark
1/14/2009 7:40:21 AM • D-Link DPR1260... • Answered on Jan 14, 2009
Adding a second printer to a d-link priter server
You need to connect the second printer to your print server then install the printer driver to your computers. If your print server has a printserver driver, run that so it will automatically find the new printer for you.
8/3/2008 6:01:26 PM • D-Link DPR1260... • Answered on Aug 03, 2008
Printers are not recognized as online by printserver
Have you check which port your PC trying to register your printer to?
9/24/2007 7:29:41 PM • D-Link DPR1260... • Answered on Sep 24, 2007
Connecting with DPR 1260
1) Signal strength to each computer might be poor (raise the DPR-1260 as high as you can afford or centralize it) 2) There are nearby wireless devices on the same channel (or adjacent channels) as yours. You might not see them, as they are neighbors or businesses, depending where the device is. 3) Wireless is very similar to Real Estate. It might be a shabby house but in the right location it's a sell. Location, Location, Location. (same as #2) 4)Make sure the device is NOT sitting on or at least 6 inches near any other electronic device, including radios, TV, cable modem, etc. As a quick fix, enter the DPR1260 configuration page and change the channel to either 1, 6 or 11, whichever gives you the best performance. Then come back here and let us know what you find. ZT3000 "Beta tester of "0"s and "1's"
8/20/2007 1:42:34 AM • D-Link DPR1260... • Answered on Aug 20, 2007
Factory reset d link DI-604 ethernet router
There should be a pinhole that allows you to do it with a paper clip...
2/16/2014 7:56:27 PM • D-Link DP... • Answered on Feb 16, 2014
2answers
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
11/12/2022 5:02:31 AM • D-Link Computers... • Answered on Nov 12, 2022
My d-link dwm-156 3g after upgrading its firmware don't working!
I am sure it is now toast and you cannot downgrade if the wrong firmware has been installed. I would ask D-Link.
5/10/2022 11:44:35 AM • D-Link Computers... • Answered on May 10, 2022
D-Link DPR1260 Rangebooster G Multifunction Print Server (790069283475) Print Server Logo
17 questions posted
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
DP D-Link
  • DP D-Link
Most Popular Question
am trying install d link tried many
  • Computers & Internet
