20 Most Recent
D-Link NetDefend DFL-200 Firewall Questions & Answers
DFL-200 UPnP
connect your router to computer with ethenret cable in lan port.
Then access your router with following link.
http://192.168.1.1
or
http://192.168.0.1
type user name as "admin" and password as "admin" or blank or 'password"
then go to advanced and enable dhcp then save settings and restart the router to take effect.
Unable to map server to storage media over the internet for back
Virtual Private Network (VPN) endpoint and pass-through support. Additional firewall features include custom and policy-based filtering options. These options have to be configured properly.
Check your configuration level and access policy.
If its a public server you have to place it in DMZ.
Check IP settings of the server. U may require a VPN tunnel
Rate if this is helpful
Thanks
Good Luck
Url blocking on dfl-200
Hi Mohan143,
Zupertails here,
you probably overlooked one small thing.
In order to actually activate the blacklist, you need to add a rule in The Firwall, LAN->Wan filter.
1) Just add a new filter, name it what you want.
2) In 'Action' select 'Allow'
3) In 'Service' select 'http-outbound'
4) Click The green Apply icon
5) Click the Yellow Apply button right
6) Click 'Activate changes'
7) Wait a couple of seconds and click on the activation link
tadaah
I need configuration aid for the DFL-210
Dear Sir/Madam,
Please check this link for more details. It may be help you.....
ftp://files.dlink.com.au/products/DFL-860/Manuals/NetDefendOS_2.12_User_Manual_v1.05.pdf
Thanks
Don't forget to rate the solution
All Public IPs
In order to use your DFL-200 as a firewall, and not a router, you will need to put it into "transparent mode." This will allow you to use only public IP addresses and you will not be using NAT.
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
