20 Most Recent
Sony DRU-820A DVD RW Dual Layer Burner Questions & Answers
Dru-820a keeps ejecting the dvd
There can be couple of issue with your DVD ROM, one can be that the belt of the DVD tray might be loose secondly the DVD which you are using might not be of good quality and last but not the least the DVD ROM head might be faulty or lence of the head might be faulty.
You can try the below mentioned fix once and then check again
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
Can find the sony device
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Click on Start, Run, and type regedit and press Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. oryou might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
select properties general troubleshoot, select driver click to reinstall drivers click update driver hope this helps you
Using nero 7 ultra enhanced,burn
Click start control
Close all open
programs
Click on
Enter
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
This folder
Upper
Filters
Lower
Filters
Upper
Filters.bak
Lower
Filters.bak
for this device
or
hope this helps
I'm trying to burn a
you will need a program like Any Dvd which removes all the protections on the dvd before it can be burnt these are on the dvd to protect against piracy or
click start control panel,administrive tools,computer management,device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
hope this helps
The draw keeps poping open after i shut it.
you might have to physically unplug the leads for this cd-rom then plug them back in this should activate the found new hardware wizard or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty
hope this helps
I Have a Wierd problem and its difficult to
go to " device manager" and expand the dvd/cd rom drives. Select your dvd rom there and right click on it, then uninstall it. Then on top of the device manager options, click on "action" and click on scan for hardware changes. Wait for it to be detected again. You may need to have the driver for your dvd drive (usually its on the cd that came with the drive ) If you don't have then just dowload the driver from the internet.
Play original movies only
My parents had a Sony drive that was the same. The guy at the store says that some sony models have a chip that detects the type of disc and will only play originals.
I am lookinf for a restore driver for my sony
yoiu do not need drivers in windows 2000 and above for any cd/dvd player/burner. check if it is listed in your hardware, if not then check inside if it is actually physicaly connected.
you did not provide any information what is the problem, what operating system and what computer specs are. if you require more detailed help, do provide these details first please.
Reading problem
Hi
Please try a cd/dvd lens cleaner if the problem persist then the lens is defective and repairing the drive will be waste of money just replace it.
No disk inserted comes when i have already
its because of several problem
1,check the speed of the dvd is matching with cd rom
2,check the latest driver installed ornot
3,go to properties of my computer-hardware-devicemanager,check cd rom
if it in yellow colour
pls do following steps
A,right click and enable
B,download cdrom disable tool from the website and enable cdrom
C,check the registry.it shold be 3
D,check any upper and lower filter in the registry
Set-up not working on sony dvd
After reformatting a computer, inserting an optical disc into a drive will not allow it to autoplay (there is no operating system to take control of the situation). If the disc is bootable and the BIOS is configured to allow booting from an optical drive, restarting the machine with the disc in it should allow the system to boot off of that disc. If this is the problem you are trying to describe, press whatever key (F2, F12, Del, etc) allows you to enter your BIOS setup program and ensure that your computer will attempt to boot from your CD/DVD drive, save your changes, and allow the computer to reboot. This should solve the issue.
