20 Most Recent
GE JES1142SJ Microwave Oven Questions & Answers
Change lightbulb
most times you have to take the outer case off (the stainless steel part) and then you can see all the wires circuitry etc. thats how you get to the light bulb. make sure you unplug the microwave first and do not touch where it says electric shock hazard it will shock you even if not plugged in
My microwave just stopped working. It still turns
It seems likely that the cyclotron has failed. If it is under warrantee then I suggest you return it to the place you bought it from to get it repaired. If it is out of warrantee, then you need to decide if the cost of repair is worth it, or whether you just buy another one.
Microwave jes1142
If the timer counts down and nothing else happens, the secondary interlock switch is bad. This switch completes the cook circuit and this is why it doesn't run. You need an ohm meter to diagnose and find the right switch. Switch failure is caused by opening the door when it is in cook mode. Push the stop button first before opening the door and this failure will cease to occur. BE CAREFUL !!
GE JES1651SJ02 Wont turn off. Fan and table turns
follow this test and fix it. God bless you
- Inspect the power cordUnplug
the power cord and check for voltage at the outlet. Also inspect for
damage, shorts, or burn marks that can be a possible safety hazard.
- Bad door switchIf your
microwave does not work at all and you know everything is plugged in
properly and the outlet is functioning, then also check the door hooks
and the door release button. Using a volt-ohm meter on RX1, check your
terminals. When your microwave door is closed you should have a reading
of zero. Once the door is open the reading should change to infinity. If
these readings do not match up, replacement of the door switch is
necessary.
- Blown fusesTo determine
if your fuse has blown out, which may attribute to your microwave not
running, you need to pull the fuse out using a pair of fuse pullers. Lay
it down and using a volt-ohm meter on RX1, check both ends of the fuse
in question. If you do not get a reading of zero, then you will need to
replace the fuse.
- Bad fan motorLocate the
fan and remove the leads. Again using the volt-ohm meter on RX1, check
the terminals. If an infinity reading is displayed, it means that the
fan has gone bad and requires replacement.
Start botton on touchpad not working
Try unplugging unit for 5 minutes then plug in and clear cancel. Re-set clock and tryto program. If this does not work, call service tech. A quilified tech will open up & test touch panel and control board.
