20 Most Recent
Danby 10.4 cu. ft. / 294 liter Upright Freezer DUF1040W Questions & Answers
Danby upright freezer plugged in a few hours ago, but coils on back are hot
If you are talking about the black condenser coli on the back of the fridge it is hot because the refrigerant is pulling all of the heat out of the fridge and trying to deposit it outside of the box. This is called hot box pull down. When the temperature inside the fridge comes down and you have product in it the coil on the back will become much cooler during operation. So if you are wondering it is nothing to be worried about, perfectly normal.
I want to register my new Danby upright
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
The blue temperature light and the green light is flashing on my danby deep freezer. Why is this?
One of these is a power light. It typically remains on while the freezer is in use. No light means either a blown bulb or no power. The other is associated with the thermostat. But it does NOT indicate that freezer temperature is appropriate. Flickering appears to indicate the bulbs are simply failing. The bulbs are neon, I think, and are not cheap. Some might try replacing such with LEDs. I have seen comment that the bulbs are not long lasting. www.manualslib.com has numerous danby freezer manuals but I do not know your model. Have a look.
Does a Danby 5 cu ft chest freezer have a drip pan? If not, how can I get rid of the rotten meat smell?
The drip pan on any freezer collects ice melts from the evaporator during the defrost cycle. Most of them are mounted on the compressor and use the compressor waste heat to evaporate the water.
If there is rotten meat smell in the drip pan it means there is also rotten meat smell in the evaporator coils and fins.
It's almost impossible to get "stuff" out of the evaporator fins unless you take the unit apart.
This means you will probably have to remove and replace the refrigerant plus evaporator and the entire process could take two 8 hour days or more.
Alternately,
after you completely wash it out you can try placing a pan of hot water in it and run it empty. The steam will condense on the evaporator and freeze. Then defrost it . Hopefully this will wash some of the funk away. You might have to do this several times.
If that doesn't work then cost wise the unit is junk.
Suggest in future wrap your meats in freezer bags or other
water/air tight containers in case power goes off.
Monitoring your freezer is a must to catch issues before smelly spoilage can set in.
I just got an older Danby freezer,,,,model dcf 480, type zs 1401,,,,my question is,,,what is the orange switch in front for?,,,on witch side should it be?,,,thanks
the switch my be a temperature monitor switch. the alarm is set to -10f to let you know that there is a temperature problem.
