20 Most Recent Lanier Ld345 Ld335 Ld245 Ld235 Ld145 Upper Fuser Roller Questions & Answers
No bottle, it is inside the transfer belt unit that hangs on the inside of the right hand door. Dump it and put it back.
Lanier Ld345... | Answered on Dec 14, 2014
Come into test mode, if it comes back the fuser service needed. -Carl
Lanier Ld345... | Answered on Dec 01, 2014
All printers are not equal. Some utilize cartridges with ink reservoirs and print heads all in one. Some only have a Separate Print head carrier with a main print head and slots for ink-filled reservoirs. You can purchase and use less expensive cartridges from on line vendors. If you elect to refill carts, be prepared for a messy venture. What many printer users fail to recognize, is the print heads do wear out and prior to complete failure, the heads either cause streaking or poor color density. To clean a print head, run under the tap for a few minutes, very hot water on both sides , metal bars and where the ink enters. When all signs of ink have vanished, replace in the printer. Do not touch metal contacts as oil will interrupt electrical communications. Do a printer test and alignment. Should work.
Lanier Office... | Answered on Feb 08, 2018
http://www.productmanuals.org/lp/?brand=Lanier&utm_source=adcenter&utm_medium=cpc&utm_term=lanier%20manual&utm_network={}&utm_campaign=FM+Brands+02-03+2
Lanier Office... | Answered on Jan 06, 2018
Are these new or refilled?
Lanier Office... | Answered on Nov 09, 2017
Lanier Ld345 Ld335 Ld245 Ld235 Ld145 Upper Fuser Roller Logo
9 questions posted
Top Lanier Office Equipment & Supplies Experts
quennie732
Adorjani Laszlo
gggg
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Lanier Office Equipment & Supplies
Most Popular Question
replace used toner bottle ld245
  • Office Equipment & Supplies
