20 Most Recent
Danby DMW119 Microwave Oven Questions & Answers
BEEPING EVERY 30 SECONDS
Your oven has a 24 month parts and labor warranty.
I would contact Danby:
Consumer Help Line 1-800-26-DANBY
(1-800-263-2629)
Hours of Operation: Monday -- Thursday 8:30am - 5:00pm EST
Friday 8:30am - 4:00pm EST
Or you may e-mail Danby Service at
[email protected]
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Model dmw1148ss microwave runs but
Press
the "Off/Clear' button to cancel anything on the display, and reset the
microwave. This is a soft reset and will simply get you out of any
program you have started. Press it when the cooking complete reminder
appears on the display.
Perform
a hard reset. Pull the plug out of the wall power supply, and wait a
moment. Plug the GE microwave back into the wall power supply to reset
any anomalies with the microwave's memory. You will need to reset the
time of day if you perform a hard reset.
Reset
the time of day. Press the "Clock" button, and turn the dial to set the
hours. Press the dial to enter. Follow the same procedure for the
minutes and a.m. or p.m. Press the "Start" button to start the clock.
Screen goes black
It's a power save function. You can adjust it. If it's a pc go to "contol panel". There will be help there.
The microwave does not heat up food
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new
microwave oven.
Howm do I reduce power down to 50%
First enter the cooking time just like normal, but then you hit the power button and then hit the digit indicating the power level you want. THEN hit start and it will start cooking.
Microwave dmw1148ss
Usually you must purchase the warranty within some specified time of the purchase, such as one week.
But your best bet is to contact the dealer where you purchased the unit. If they are able, they will be eager to sell you an extended warranty.
We're happy to help and we appreciate your thoughtful rating of our answer.
Danby turntable keeps spinning
2 THINGS COME TO MIND--A BAD ELECTRONIC CONTROL PANEL (BEHIND THE KEYBOARD) USUALLY FROM A POWER SURGE,,,,OR A BAD SOOR SWITCH--THIS REPAIR WOULD NEED A TECH--TUNICA
Beeps every 30 seconds
Your oven has a 24 month parts and labor warranty. I would contact Danby:
(1-800-263-2629)
Or you may
[email protected]We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Exterior
If it's portable, I would return it just to be safe.
Then test the replacement right away.
Danby Designer 1.1 cu.ft. Microwave
Weird that it worked when you left then not. Have you had the lights inside of your house dimming off and on?? It could mean a bad neutral connection to your house from the power pole. That can cause the low voltage transformer on the timer board to burn out. So the fuse in the unit will not even blow but still kill the Low Voltage transformer. If sounds possible call your power company to do a "load test" on the incoming power lines to your house.. They don't typically even charge to do that. They take out your meter and put a tester in that spot that tests the supply to your house.
...have Danby 1.0 cu. ft.
When talking about "Power Level", there is a misconception that the cooking power is being adjusted. This is not the case. The user is actually adjusting the duty cycle of the Magnetron. For instance at 30%, the Magnetron will be turned on for 20 sec. and off for 40 sec. A loud 60 cycle hum is usually caused by a shorted Magnetron. Thus the unit is not economically repairable.
