20 Most Recent
Acer Altos G710 Server Questions & Answers
My server can't boot
Hi ,
You have not mentioned which Operating System . If its for 2003 follow the steps.
To install the Recovery Console as a startup option:
- While Windows is running, insert the Windows Server 2003 CD
in the computer's CD or DVD drive.
- Click Start, and then click Run.
- In the Open box, type the following line, where
drive is the drive letter of the computer's CD drive
or DVD drive that contains the Windows Server 2003 CD, and then click OK:
drive:\i386\winnt32.exe /cmdcons
To install Recovery console as a startup option for Windows Server 2003 x64 edition, type the following line:
drive:\amd64\winnt32.exe /cmdcons
- Click Yes when the message appears, to install the Recovery Console.
- When you receive the message that states that the Recovery
Console is successfully installed, click OK.
- To use the Recovery Console, restart the computer, and then
use the ARROW keys to select Microsoft Windows Recovery
Console in the Please select the operating system to
start list.
Back to the top
How to Remove the Recovery Console
loadTOCNode(2, 'summary');
As a precaution, do not remove the Recovery Console. However, if
you want to remove the Recovery Console, you must do so manually.
To
remove the Recovery Console, follow these steps:
- Restart the computer.
- Click Start, and then click My Computer.
- Turn on the Show hidden files and folders
option (if it is not already turned on). To do so, follow these steps:
- On the Tools menu, click Folder Options.
- Click the View tab.
- Click Show hidden files and folders,
click to clear the Hide protected operating system files
(Recommended) check box (if it is selected), and then click OK.
- Double-click the drive letter that represents the hard disk
on which you installed the Recovery Console.
- Delete the Cmdcons folder from the root folder, and then
delete the Cmldr file. To do so, follow these steps:
- Right-click Cmdcons, and then click Delete. Follow the instructions that appear on the screen, and then
click Yes to confirm the deletion.
- Right-click Cmldr, and then click Delete. Follow the instructions that appear on the screen, and then
- Remove the Recovery Console entry from the Boot.ini file.
To do so, follow these steps.
WARNING: Incorrectly modifying the Boot.ini file may prevent your
computer from restarting. Make sure that you delete only the entry for the
Recovery Console.
- At the root folder, right-click the Boot.ini file, and then click Properties. Click to clear the Read-only check box, and
then click OK.
- Open the Boot.ini file in Notepad.
- Locate the Recovery Console entry, and then delete it.
The Recovery Console entry looks similar to the following line:
C:\cmdcons\bootsect.dat="Microsoft Windows Recovery Console" /cmdcons
- On the File menu, click Save, and then click Exit to quit Notepad.
- Change the attribute for the Boot.ini file back to
Read-only. To do so, right-click Boot.ini, and then click Properties. Click to select the Read-only check box, and
then click OK.
While i am installing win
You may need to go into your BIOS and make sure it is reconizing your hard drive. If you do not see it, make sure you have the hard drive cable connected correctly and have the latest drivers installed for the drive. (IDE, SATA, SCSI, etc.) Once the BIOS see the drive, you should have no problem. Good Luck
C2Solutions
Updated dated onboard scsi controller
Download and install latest firmware once again will resolve your problem.
Revert back for more assistance and give your valuable feedback/rating for the solution provided.
Thank you for using Fixya.
About SCSI
Replace the hard drive with a drive that is the same type and the same size, or larger. It will rebuild itself.
By same type I mean that the connector on the back of the drive and the speed of the drive interface must be the same. If the new drive spins at a different rate it will not create a problem, except that if it is slower it will make read/writes slower. If it is larger it will only use part of its capacity, matching the capacity of the other drives.
Note that if you were to replace all drives with larger drives (one at a time) the capacity of the entire array would be the same as the original. If you want a larger array it must be built from the start with that larger capacity.
Take out the bad drive. If you can get the exact same drive, do it, otherwise look it up on the manufacturers web site to find out size and type.
While there are a few possible RAID configurations that you could be using on that server, the chances are overwhelming that it is RAID level 5 that you are using. This RAID level is tolerant of a single drive failure. If you lose another drive before your new drive rebuilds your data will be lost. Hopefully you have a backup.
RAID 5 stripes the data and the parity data across all available drives and when a drive fails, the missing data is rebuilt on the fly from the parity data. When a replacement drive is installed the parity data is used to rebuild the data that belongs on that drive. The advantages of RAID 5 are fault tolerance (of a single drive) and speed because each drive only has to provide or write its portion of the total data being accessed or written.
I need Acer g710 Ram
If you need Ram, you need to contact your server manufacturer to find a product number for your server and memory model/size.
You can add up 16GB of RAM DDR2.
Many manufacturers also provide compatible memory like Transcend or Kingmax.
Can i help you with anything else ?
PXE-E61
1.) Verify that both the local and remote network interfaces are connected AND enabled/configured.
2.) Replace the cable.
If the system no longer reports a "Media test failure" error then the physical layer is good. Either your system will begin to PXE boot or you will need to verify that a PXE server is available/reachable in the same subnet/VLAN. (Barring any ACL issues, etc.)
Not much else to cover here. Considering this issue closed.
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
My Acer X1110 switches off as soon as blue light comes on?
it needs service, and service manuals are hard to find on anything by the likes of ACER.
this projector worked for 12 long years, did you own it 12 or bought a bad projector, no history told as I can buy dead projectors all day long. and hard nut problems even hacking done.
Acer X1110 data projector Standard throw projector..
did you know most projectors have serious grade protective devices inside??? (tamper and overheating are 2)
did you read owners manual page 32 yet, errors.
LED codes.?
there are 4 LED, and all 4 matter, projector turned (ON) (not one =1)
also in pairs glowing and also if blinking or not, so read page 32
it tells all that.
my guess is overheat failures, even cold, due fan slow or packed in lint after 12 years of use and no service done,.
https://manualzz.com/doc/49497108/acer-x1110-user-manual
some have dust filtler
a shop first cleans is out first, and check fan RPM with and LED tachometer.
this is all SOP.
