20 Most Recent Casio (41644) 2.3 in. Handheld Television Questions & Answers
VHF will scroll the line through and not stop on a
All television stations went to digital, these are analog devices. It renders these cool portables useless.
8/28/2010 4:37:31 PM • Casio (41644)... • Answered on Aug 28, 2010
I have a Casio tv-995and
It opens directly below thw LCD screen. Push in and slide down, where the 4 dots are below the screen. It opens from the front.
8/28/2010 4:35:23 PM • Casio (41644)... • Answered on Aug 28, 2010
I can't get my CASIO model TV 995B open to replace
hold the tv with the front facing the top; then under the tuning buttons you should be able to push and slide down the bottom of the tv.. if i had a bigger picture of what yours look like then i could help more. or even go to casio.com and get manual for it.
3/14/2010 4:14:57 AM • Casio (41644)... • Answered on Mar 14, 2010
0answers
I have a Casio 130 till & cash drawer won't open
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwiklqL7xJSCAxWKvokEHXqmB5IQwqsBegQIDhAG&url=https%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3DF-idzuhFUXo&usg=AOvVaw3BRi9I-eeeMtbi-rA21L3p&opi=89978449
10/26/2023 8:21:18 PM • Casio Televison... • Answered on Oct 26, 2023
Free download avast anti virus
To download avast anti virus go to get into my pc to download the free version
11/8/2022 2:10:31 AM • Casio Televison... • Answered on Nov 08, 2022
Hasnt worked since going digital
since analog went bye bye it will not work
12/1/2021 9:00:50 PM • Casio Televison... • Answered on Dec 01, 2021
TV-880. How can I receive channel 36?
https://support.casio.com/en/manual/manualfile.php?cid=015001001
11/12/2020 3:13:54 AM • Casio Televison... • Answered on Nov 12, 2020
Casio fx 8100
Go to the internet and write 'user manual for Casio fx 8100 on the search bar thereafter you will be able to download user manual for your calculator.
6/16/2019 7:59:07 PM • Casio Televison... • Answered on Jun 16, 2019
My Casio handheld LCD color tv-900 wont turn on and no audio. I tried new batteries but no help occurs..
Actually this device is hard to repair. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
1/17/2017 7:07:45 AM • Casio Televison... • Answered on Jan 17, 2017
Casio TV-600. Where can I get a manual?
Go to
CASIO TV-600B Service Manual free download, schematics, eeprom ...
elektrotanya.com/casio_tv-600b.pdf/download.html
6/8/2016 10:48:54 PM • Casio Televison... • Answered on Jun 08, 2016
Need to replace battery in my casio 593 wristwatch
Old question, but I just had to do this, so posting for anyone else's benefit: 1. Remove and keep safe the 4 small screws at the corners on the back 2. Carefully remove the back, ensuring the black seal stays in place ideally attached to the back. 3. The battery is partly visible under the metal cover. Remove the whole assembly from the case of the watch, remembering which way round it goes 4. Using a very small flathead screwdriver or similar, lever the 4 clips on the metal cover gently away from white plastic body and up, one at a time, working round until the metal cover is loose. You may need to go round a few times. Remember which way round it goes. 5. The battery is held in place with a sticky pad. Don't pull it, or the display will come loose. Gently lever it away from the green circuit board. 6. When the battery is loose, if the sticky pad is on the battery remove and reattach to the circuit board just inside the circle where the battery sits. 7. Stick the new battery down, plus side(with writing on) towards you. Be careful not to touch with your hands to maximise battery life (eg use a PVC glove) 8. Insert the assembly back in the case, battery upwards, the same way round. Lower the metal cover back over the battery, ensuring it covers the battery not the springy clip protruding from the circuit board. Align the 4 clips with the gaps they fitted in before and press into place in all 4 points. 9. The watch should now show a working display. If the light doesn't work, the battery is not in correctly. If the display is showing random rubbish, it probably came loose. Try carefully easing the circuit board one way or the other in the white body to realign it, but if this fails, remove the metal cover and remove the circuit board from the white cover, replace both, and try again. 10. Replace the back taking care to put the seal in place and replace the 4 screws. Set the time according to the manual. It will tick for about 5 minutes, and show a dot to the left of the day abbreviation. No idea why. It stops after a while.
10/11/2014 7:44:50 PM • Casio Televison... • Answered on Oct 11, 2014
0answers
Casio ml71
Be the first to answer 3/30/2014 8:01:00 AM • Casio Televison... • Posted on Mar 30, 2014Be the first to answer
Casio (41644) 2.3 in. Handheld Television Logo
6 questions posted
Top Casio Televison & Video Experts
Johnny 1000
Ngoro
Are you a Casio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Casio Televison & Video
Most Popular Question
casio tv 995and
  • Televison & Video
