20 Most Recent
Gateway FPD2185W 21 in. LCD Television Questions & Answers
High pitched noise (squeal)
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Model 2100 FPD2185W Monitor
It's very likely a problem with some of the capacitors in the power supply area. You can search for similar fixes here on this site. I'm ordering parts now for mine. Two of the eight tall/blue capacitors in a bunch have tops that are bulging (but I'll replace all eight since they're cheap). There's a pair of two in the middle of the same board on mine with bulging tops and there are four transistors in that same area that look like they got too hot. Most people seem to be getting away with only replacing the bulged capacitors but here is my total part list from digikey.com:
785-1106-1-ND quantity 2 (the D405-marked transistors)
785-1114-1-ND quantity 2 (the D408-marked transistors)
P12389-ND quantity 8 (the 470uF capacitors)
P12383-ND quantity 2 (the 220uF capacitors)
The total part list is about $7.50 with another $2.50 or less shipping. It's a pain to take apart, given the small connectors inside. The fix assumes you have soldering skills.
Go with these from digikey versus Radio Shack. They're rated for 220 degrees fahrenheit versus only 85 degrees and they're about a third less cost.
Monitor works intermittently
Hi Michael, it does sound like the monitor then. The most likely cause is bad capacitors in the power supply. Typically a cheap repair but you do have to solder and such. Unless you have to have a very expensive monitor its probably better to just replace it since basic monitors are so cheap these days. Good luck.
Magnavox capacitors or bad tried
just replace the caps with the proper uF specification value and the voltage that is on the cap or slightly higher , never replace with a lesser voltage cap.
Dead, no power
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both. In your case, likely the power section. Check for micro-fuses while you're in there.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it off and on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for some time and then try again.
If you aren't tech savvy, don't worry, read the rest of this solution and watch the videos.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V or 25V or even a 50V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering, and even then, you should go OVER, not under the uF rating).
Most of the caps that go are 10V 1000uF or 3300uF.
I found some great videos of the procedure (for many Samsungs with the same issue) on youtube.
http://www.youtube.com/watch?v=Mm51C_RDIZE
http://www.youtube.com/watch?v=BNHHrgX_6cs&feature=related
http://www.youtube.com/watch?v=8l0AUj8QUkg&NR=1&feature=fvwp
http://www.youtube.com/watch?v=Y7b_nTaZYcU&feature=related
As you can see, this issue spans plasma TVs, as well as large and small LCD TVs and monitors.
The parts are cheap, and skill required is minimal.
Parts can be ordered online from www.digikey.com and should arrive next day - the parts are typically less than $1 each.
Gateway FPD2185W 21 monitor screen
I order these parts from www.digikey.com because they are less than a buck a piece, and arrive next day (shiping here is a flat $8 rate, your location may vary)
I saw the fix for
Almost all monitors will accept a 60Hz signal at almost any resolution, however I suggest 1024 X 768 at 60Hz...then you can try higher frequencies such as 75 Hz or more after you have established that the unit is functional.
