20 Most Recent Philips 50PF7320A 50 in. Plasma HDTV Questions & Answers
2answers
Philips plasma tv. has green line on left side of screen.
Using your TV's remote control press the right cursor button three times and it will adjust the Screen to the right and the green line will disappear. Use the left button if your green line is on the left.
Thanks to:
http://www.tivocommunity.com/tivo-vb/showthread.php?t=319984
1/21/2018 7:38:45 PM • Philips... • Answered on Jan 21, 2018
0answers
The top half of the
Be the first to answer 10/22/2017 8:39:03 AM • Philips... • Posted on Oct 22, 2017Be the first to answer
0answers
What is 34 Tuner 1...my Mitsubishi wd 60737 is
It will be best for you to contact the service center for Mitsubishi.
10/23/2013 4:35:14 PM • Philips... • Answered on Oct 23, 2013
My philips tv flat screen keeps shutting off and a
Not sure what code since you didn't say, but here is the code breakdown.
When the TV does this, the RED LED on the front will blink. For digits 1-10 it will blink pause then repeat. For numbers with 2 digits it will blink the first digit slow and then second digit fast. So 25 would be 2 slow blinks followed by 5 fast blinks.
Error Description Error/Prot Detected by Device Defective module Result
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
14 Supply Class D amplifiers
14 Supply Audio part SSB
17 MPIF1 audio supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
43 Hi Rate Front End
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
10/23/2013 4:02:21 PM • Philips... • Answered on Oct 23, 2013
50 PF7320/10 won't turn on- clicks and then clicks off.
If you used capacitors from Radio Shack, that may be why. RS uses whatever they can get in the values spec'd, so they really are only adequate for general purpose use. When I do a repair on a power supply, I order "High Ripple Current" types, or even the newer style polymer types, and step up in the working voltage slightly. So a 16 volt cap gets a 25 colt cap, a 25 volt cap gets a 35 volt cap and sometimes a 35 volt cap will get a 50 volt cap.Now- if you did order high ripple types, check the transistors in the inverter section. They can fail too. If they check okay, then look at the inverter transformers. They do make a test tool for them, and not too expensive for what it does, but you can also check the transformers with a "Grid Dip Meter". They must be out of the circuit or you may get some false faults.Sometimes you can find a faulty transformer by locking the PWM controller on- the method is usually described in the data sheets for that particular controller IC from the manufacturers data sheets, and if a transformer is bad, it may reveal itself with a whine, or by flaming out. Digikey dot com does have a wide selection of the PWM controller IC's, and you can get the datasheet online from them if they carry that IC. Otherwise you need to rely upon the manufacturer's website or a site like Datasheet archive.If the set has more than 3000 hours of use- consider replacing the CCFL tubes.
11/1/2012 5:56:09 PM • Philips... • Answered on Nov 01, 2012
0answers
TV does not have aHDMI port so what audio and vdeo
Hello
There is a side socket connection set on your Philips TV. You can connect two audio channels Left and Right and one Video. Connect these socket with an AV cable, and connect the other end of that cable to your SKY HD boxe's respective output sockets. Then select the TV input to AV by going into its menu and surfing through it. That is all for settings. OK
1/16/2011 12:52:22 PM • Philips... • Answered on Jan 16, 2011
Need manual
You can download and print the instruction manual in PDF format by clicking this link.
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
11/25/2010 10:27:42 PM • Philips... • Answered on Nov 25, 2010
I have to unplug wait for the power light to stop
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
5/5/2010 7:26:41 PM • Philips... • Answered on May 05, 2010
Red light flashing.set will not start up.
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
37 Channel decoder
39 POD Interface
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
5/5/2010 7:07:42 PM • Philips... • Answered on May 05, 2010
2answers
How do you update software?
http://www.google.com/search?sourceid=navclient&ie=UTF-8&rlz=1T4ADBF_enUS255US256&q=50PF7320A%2bsoftware%2bupdate
Note some people seem to have said, in those search results, that the updated software was worse than the original. So you might want to read those first before you try to update.
Good Luck.
5/5/2010 6:50:31 PM • Philips... • Answered on May 05, 2010
2answers
My 50 in plasma has seven red lights flashing
If it is blinking red 7 times, and then repeating that would be error code 7 (8V6 supply). Power supply
1 I2C1
2 I2C2
3 I2C3
4 I2C4
5 VIPER
6 5V supply
7 8V6 supply
8 1.2V DC/DC
11 3.3V DC/DC
12 12V supply
18 MPIF1 ref freq
25 Supply fault
27 Phoenix
28 MOP
29 AVIP1
31 AVIP2
32 MPIF1
34 Tuner1
39 POD Interface
44 Main NVM
45 Columbus
53 VIPER
63 PDP Display
5/5/2010 6:47:29 PM • Philips... • Answered on May 05, 2010
My Philips plasma only shows half the screen
This model has PiP (Picture In Picture), find the button on the remote or check manual, this mode is most likely turned on and is being shared with one of the AV channels, or try turning on a plugged in SCART device to see if this picture shows on the other half of screen.
11/23/2009 11:21:33 PM • Philips... • Answered on Nov 23, 2009
0answers
OUR 50 INCH HD AMBLIGHT PLASMA MODEL 50PF9631D HAS
This is know as the" Blue Haze" defect. A tech may try to lower the screen voltages for you. Realign Ve, 110volts to 100volts. Vset from 195volts to 188volts...and the Vs from 197volts to 190volts. This was an authorized fix early in 2007. But more importantly you will have to live with this, as replacing the plasma screen is very costly. You probably have a bad screen.....SORRY!!!!!!
10/20/2009 3:33:04 AM • Philips... • Answered on Oct 20, 2009
Hello, i have a 50 inch philips flat tv model #
Unfortunately, i have found in my experience is when this problem occours you need to replace the plasma panel, which can be a costly thing to do and takes a little bit of planned time. Other than that you can try to replace the X-sus printed circuit board or the Y-sus printed circuit board. Those two boards control the screen circuitry, Good Luck.
9/26/2009 4:43:31 AM • Philips... • Answered on Sep 26, 2009
Philips 50PF7320A 50 in. Plasma HDTV Logo
51 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
philips plasma tv green line left side
  • Televison & Video
