20 Most Recent
Fujitsu Siemens AMILO Pro V7010 Notebook Questions & Answers
How do i change the keyboard on a fujitsu L7310GW
This laptop is built similarly to most others.
There is an escushen that fits neatly across the top of the keyboard, covering up the fixing screws. Remove it by gentle but firm prying with your fingernails. Don't use a screwdriver or you will mark/damage the plastic. Check to see if the screws are visible when this escushen is removed, if not, remove the base as the top will have to be removed first.
All will be revealed at or before that last point.
Hope this helps.
I have recently installed windows 7 to a fujitsu amilo li 2727
I have been through this myself, the software you are missing is called
Launch Manager. Browse to Li 2727 on
http://ts.fujitsu.com/support/downloads.html and download the drivers
for vista, verified working on win7 ultimate. Install launch manager and
the wireless + brightness hotkeys will work again without any further
setup!
I have an Amilo Pro V7010 Laptop, but the power-in doesn't work. Nor will the back come off, can someone link me to a video/guide how to dissemble the V7010 please?
Try you manufacturers website and look for manuals.Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Look for manuals.Normally you just turn the laptop over and start removing screws. Remove the devices on the bottom such as the memory, dvd drive, hard drive, wireless card, battery, etc. Look inside the case where these devices came from and you might see more screws to remove. Then turn the laptop over, open the lid, remove the strip that is above the keyboard, but be careful there might be a cable behind it. Remove the keyboard, be careful there is a cable behind it. Remove the lcd screen hinges and lift the lcd screen off and pull the cables and wires that come from the lcd screen out of the laptop. Remove the palmrest then the motherboard will be exposed. Remove the screw that hold the motherboard to the bottom base.have some cups with labels on them so you will know where the screws came from. Also have a digital camera handy to take pictures.
System corrupt...want to do full restore
welcome to fixya
umm if you did not make any backup disk for your computer then there is nothing to be done at your home you will have to take to a service center
unless you know someone with the same computer type or you could try to reboot it with a different reboot /cd
i have a acer computer and i rebooted it with a reboot disk from gateway so this might work but not always
hope this helps out have a good day
Laptop failure
hinever leave a system running unattended for long period of time without a battery back up (UPS), as low and high current spikes will cause damage to the circuitry of the computers mainboard. Have you tried using the AC adapter to power up the computer ? if that works and the battery is dead, simply replace the battery. if the system is not powering up at all, then the issue is bad AC adapter or the mainboard is damaged from overload of current.
Amilo 2727 wireless adapter hotkeys
Please uninstall the driver though Device Manager and get it install from the disc given by manufacture website or download the latest driver.
Path is :
My Computer(right click)->Properties ->Hardware->Network Adaptor
Cant switch my wireless on
do you have an Fn button(function) the letters Fn are usually a different colour.If so you need to hold it down and then press the wireless button.The wireless button should have the same coloured letters or symbol looks like an aerial
good luck
any prob let me know
HI I PRESS FN&F1 ON MY LI2727 BUT NOTHING
Had the same with wireless and brightness hotkeys not working, you might be missing
http://ts.fujitsu.com/support/downloads.html and download the launch manager for windows vista, verified by myself it works on windows 7 aswell. Install launch manager and
setup!
