20 Most Recent HP PL5000N 50 in. HDTV Plasma Television Questions & Answers
0answers
Kids messed with it and now it's no longer showing
go to menu, video settings, display and choose wide.
7/24/2009 10:51:25 PM • HP PL5000N 50... • Answered on Jul 24, 2009
Plasma TV Background noise
Here's the number to HP case management 877-917-4380 ext.79, try this number and be firm that they need to fix this, I just had an HP plasma that was 3 yrs old replaced for free, no charge. Good luck
2/4/2009 11:30:48 PM • HP PL5000N 50... • Answered on Feb 04, 2009
PlayStation 4 to All-In-One PC
4/2/2023 3:37:21 AM • HP Televison &... • Answered on Apr 02, 2023
Where is the Logik LPV 09 HP reset button
The location of the reset button on the Logik LPV 09 HP would likely be in the owner's manual or on the company's website. It is also possible that the device does not have a physical reset button and can be reset through software or by unplugging the device for a certain amount of time. If you cannot find the information in the manual or on the website, you should contact the manufacturer for assistance. if i was able to help my cashapp $ralphpapi thank you have a blessing day
1/15/2023 9:00:51 PM • HP Televison &... • Answered on Jan 15, 2023
Amazon Prime Video on HP laptop, sound but no picture, how to fix
This is most likely related to the wrong drivers or missing codecs for video playback. You did not post the type of computer or the operating system information though
5/3/2022 12:29:00 PM • HP Televison &... • Answered on May 03, 2022
Televisor Samsung Model: HP -S5053 Model Code: HP S5053X/XAA Type: CD50P7 AL ENCENDER SE ESCUCHA PERO NO SE VE. QUE PODRA SER LA TARJETA DE VIDEO?
If you wish to get some details; check the site linked here. Pull up older posts. https://elektrotricks.blogspot.com/ https://electronicshelponline.blogspot.com/ faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Search the site by type in the brand name of your set, in its search bar at the right side column, and press enter.
3/19/2021 3:06:52 PM • HP Televison &... • Answered on Mar 19, 2021
Greetings i am a technophobe trying to connect hp laptop to conia cpdp4290 plasma tv Little help?
does tv device have a hdmi-1 input does laptop have a hdmi-1 output port https://en.wikipedia.org/wiki/HDMI
5/3/2019 10:15:27 AM • HP Televison &... • Answered on May 03, 2019
I try to start a HP iq775. When I press the power button I heard one short beep and I see a red light red and then blue, and turn off inmediately. The PC won't start. The power supply works fine. Help
All HP iq77x all-in-one PCs suffer from the same problem of a faulty motherboard. This is primarily a soldering issue on the graphics chip,which develops cracks in the solder balls. The PCs contained a separate graphics card, which goes faulty first. This can be removed and the display connector can be moved on the motherboard to use the on-board graphics. This will eventually show the same issue. A short term fix was to heat the graphics chip with a hot air gun or other means (plenty of suggestions can be found on-line) which sometimes works for a few weeks at most. The only 'permanent' fix is to have the chip professionally removed and re-soldered; an expensive option. If you are lucky, your PC is still wired to use the add-on graphics card, in which case you might be able to remove this and rewire for the motherboard graphics.
3/21/2019 7:33:33 PM • HP Televison &... • Answered on Mar 21, 2019
How do I screen mirror my HP laptop to my TCL smart TV?
look on your f buttons f5 on mine
3/21/2019 3:01:20 AM • HP Televison &... • Answered on Mar 21, 2019
I have a HP MD5820N tv and it started making a loud humming noise and the colour went all dark and flickering and now will not turn on, the red lights flashes twice under the light bulb and thermometer pictures
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. https://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size. Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview./
11/8/2018 1:38:19 PM • HP Televison &... • Answered on Nov 08, 2018
HP Touchsmart 310-1033. My computer works, however; I can't see the screen too clearly. It flashes or blinks as if it's going out. I did a diagnostics and then took it to the shop to do their diagnostics and nothing. It's not a hardware issue. The repair shop wants to charge me $99 just to open up the computer to see. I'm looking for a less affordable option. A DIY option, if possible. Does anyone know what can be the issue? As I mentioned before, computer works, I just can't see the screen. It looks like how a TV looks with white snow or white noise or fuzzy.
The first thing to do is go into the device manager and delete the drivers for the display and let windows reinstall them. It may be a bad or out of date driver. So when you restart the computer it will put the driver back. Since you did not post the operating system, there is not a lot more I can tell you. If this does not help, you can try an external monitor to see if the problem is present there. If it is then it may be a display chipset issue.
7/15/2018 11:11:34 PM • HP Televison &... • Answered on Jul 15, 2018
What do you plug the hp reulatory grlyb-0311 into
What is a grlyb-0311 ??
2/8/2018 10:46:47 PM • HP Televison &... • Answered on Feb 08, 2018
How do I connect a 32in Viano TV to a HP 20 all in one computer
you cannot connect them an all in one computer does not support a separate monitor
1/26/2018 5:33:17 AM • HP Televison &... • Answered on Jan 26, 2018
White vertical bars on HP PL4260N Plasma TV. What recommendations for repairs and or boards affected in TV set
If those bars are vertical are going up and down and not horizontal that means the lower circuit board that connect to the plasma panel are bad most likely this is an LG TV but this is not something that can be fixed you can take it apart while at least an hour after it's unplugged before you can touch ID cards along the long circuit board see if there's any connection connection connection that you can disconnect and reconnect and very carefully clean up possibly this could be the problem but usually when you have that type of line which is a vertical line you have a bad panel and that's not good and I'm betting this is an LG TV
1/26/2018 4:34:38 AM • HP Televison &... • Answered on Jan 26, 2018
Hp 2000 bluray says unknown disc, will not recognize the disc, even if we put anotherblu ray in and play it. This is the se ond fresh disc of this movie. Thanks
try a laser disc cleaner. https://www.ebay.co.uk/i/162805447175?chn=ps&adgroupid=52097426788&rlsatarget=pla-445083143997&abcId=1058846&adtype=pla&merchantid=115136089&poi=&googleloc=9046354&device=c&campaignid=863276125&crdt=0
1/13/2018 12:42:02 AM • HP Televison &... • Answered on Jan 13, 2018
HP PL5000N 50 in. HDTV Plasma Television Logo
Popular Tags
7 questions posted
Top HP Televison & Video Experts
 Mikey
Mikey
Stan Ford
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • HP Televison & Video
Most Popular Question
kids messed now s no longer showing
  • Televison & Video
