20 Most Recent HP Md6580n 65 in. HDTV Questions & Answers
2answers
I have a 65" HP md6580n....Problem is the TV shuts off after 30-35 minutes and the 2 red lights are alternating back and forth.....KURT
Sounds likely it's overheating. Unplug tv, pull control panel vacuum or blow all the dirt and pet hair and stuff off the fans and control board. Make sure vents are clear, replace panel, plug tv in. Hopefully this helps!
1/29/2016 10:38:56 PM • HP Md6580n 65... • Answered on Jan 29, 2016
Will not come on red light only?
Same issue and still no solution. 2 red lights as soon as I plug in and wont turn on. I pulled out lamp and blew out the dust put lamp back in and nothing. Please Help!! e-mail me thanks Matthew Fulton [email protected]
1/23/2015 1:47:58 AM • HP Md6580n 65... • Answered on Jan 23, 2015
0answers
Hp dlp 65 shuts down
Shut downs occur for variety of reasons like Over heating of processor Any hardware component failure Virus or any software issue Battery problem for laptop and smps problem for pc If u specify the exact circumstance and at what point the shutdown happens it will be easy to help.....
12/23/2013 4:59:40 AM • HP Md6580n 65... • Answered on Dec 23, 2013
Color Wheel
For more information go to http://electronicshelponline.blogspot.com/ Pull up older posts. One of it have details with illustrations.
12/16/2013 9:06:14 AM • HP Md6580n 65... • Answered on Dec 16, 2013
manual
0answers
What cause polarization in HP TV
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window.
12/9/2012 7:04:08 AM • HP Md6580n 65... • Answered on Dec 09, 2012
Blinking lights on HP MD6580n
Sounds like the power supply is overheating.
10/10/2012 1:52:05 AM • HP Md6580n 65... • Answered on Oct 10, 2012
Fan problems...cannot hear anymore. Bulb
Hello
You can replce the cooling fan of your tV. For that, you have to open your tV. You must have a sound knoledge in electronics to do the work. If you have. preoceeding are given here. Follow it please.
[1]]Disconnect all attached components and the power cable from the outlet. Maneuver the DLP to allow access to the rear of the television. Allow the set to cool for at least one hour if it was recently used.
[2] Remove the rear panel of the television and locate the cooling fan. It is usually located at the rear of the television casing near a grated opening for ventilation purposes. If multiple fans are installed, the cooling fan usually is the larger one. Avoid unnecessarily disconnecting any cables or components from the television.
[3] Remove the projection bulb and set aside to avoid any damage. Avoid touching the bulb surface directly to prevent any permanent damage to the bulb. Note any cables or screws that you remove to allow you to reinstall them correctly.
[4] Unscrew the cooling fan case from the television housing and carefully remove it from its place. Disconnect any power cables from the circuit board that is connected to the fan. Remove the fan from the housing or replace the entire housing, depending on the manufacturer. Use compressed air to remove any dust or loose debris that can damage the television.
components.
[5] Secure the fan to the television. Connect any previously removed cables. Place the projection lamp housing back in place and replace the cover on the rear of the television. Power on the television to ensure the fan is active and no unnecessary noise is present.
Fan and its type number will be printed on fan's body itself. Look ofr the same type and number. OK.
7/31/2011 4:33:26 PM • HP Md6580n 65... • Answered on Jul 31, 2011
2answers
My hp 65" dlp tv
Yes, I would advice you to replaced the lamp because high chance that it was already faulty and trigger the symptoms. The unit will not power up unless the bulb is in good condition because of the protection circuitry which will enable if there's a bulb malfunction. You may buy online for the replacement, click this LINK.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
6/17/2011 11:33:21 PM • HP Md6580n 65... • Answered on Jun 17, 2011
Were can i buy a
Here is a direct link for part # HP L1798-80001 (color wheel):
https://www.myallparts.com/hp-l179880001-color-wheel-p-2178.html
I emailed them and they said they have one in-stock, so you may want to hurry as this seems to be a rare part!
Thank you and best of luck!! :D
Please accept and rate!
5/17/2011 8:40:50 PM • HP Md6580n 65... • Answered on May 17, 2011
I have an HP md6580n 65" DLP. It has been in my
Hello
Reset your TV to Factory reset. This will rectify your problem. To turn it to factory reset:
Press Settings, go to Setup > Factory reset, press OK, and select Yes
5/12/2011 7:31:29 AM • HP Md6580n 65... • Answered on May 12, 2011
Blurry image, flickering and 6
It is the convergence module that is bad, need to change the convergence IC's, or the buy a new convergence module at www.partsore.com
2/7/2011 10:16:55 PM • HP Md6580n 65... • Answered on Feb 07, 2011
HP Md6580n 65 in. HDTV Logo
38 questions posted
Top HP Televison & Video Experts
 Mikey
Mikey
Stan Ford
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • HP Televison & Video
Most Popular Question
buy
  • Televison & Video
