20 Most Recent
Belkin F5D9050 Wireless G Plus MIMO USB Network Adapter Questions & Answers
Windows 7 driver update for Belkin F5D9050
Im Not sure this will Work
But in most Cases it will So I think its Worth a try
You will need to find the version of the Adapter
And After that Goto www.belkin.com/support
On the top right hand side on the search type F5D9050
On the results select the Link that has the Drivers
Download the Driver for the version of your Adapter
Right click on the downloaded file and select Properties
Click on the compatibility tab
Select Run this Program in compatibility mode for Windows Vista SP1
Click Apply
Now install the Drivers
Advanced configuration settings for the Belkin wireless G Plus mimo network adapter
Enable the Wireless Zero Configuration service so it starts up automatically, go to the Start button. Select the Settings option and then select Control Panel. If you are using the Windows XP view, select the Performance and Maintenance category and then select Administrative Tools. If you are using the Classic View, then select Administrative Tools. Click the Services icon in the left pane. Click the Wireless Zero Configuration icon in the right pane and change the Startup Type dropbox to Automatic. This setting will set the service to start automatically at boot time. Then click the Start button to start the Wireless Zero Wireless Zero Configuration service and click the OK button.
My wireless card is not
http://www.belkin.com/uk/support/article/?lid=enu&pid=F5D9050uk&aid=6222&scid=283
go there and read what it says your drivers can be found there
If this helped please vote
Can a belkin network card f5d7050 work with a
As MIMO is compatible with all wireless g products there shouldn't be any issues at all....
so some questions:
- do you have other wireless devices working with the router? if so can you duplicate their settings for this n/w card?
- have you set security on the router?
- what are you using to connect to the network the windows interface (assuming it's PC not MAC based) or the Belkin one?
i have a linksys g n/w card attached to my MIMO router & it's fine so I'm sure that this is solvable!
I want to go wireless and someone has lent me a
From
this link you can download the official drivers for your Belkin wireless network adapter. Take care that you have to choose which version do you have, version 3 or version 4. It has to be located somewhere on the device.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
When i run the setup.exe on windows ME it shows a
if you have the cd that came along with the adapter, you can install manually from that....Click advanced options in the found new hardware wizard and click next...click i ll chose the driver to install in the next page and select the hardware type as network adapters...click on have disk and locate the file rt73.inf or rt73.sys in cd...thats it
Periodic Lost of Conection
I experienced this problem before, what mine turned out to be was that when I configured the router to accept a passphrase the problem would appear it worked fine without the passphrase but this is not secure at all. I tried a few things, but nothing worked. I ended up getting a NetGear Router.
Hope this helps
Usb network adapter adapter. I want to configure
If you ar eusing vista go to the small wireless indicator on your toolbar..dble click it then click connect to network...click on your connecion and it wil as you if you want to save it...probably similiar to XP
Win xp drivers
You can download the device drivers for your model Belkin motherboard from the Belkin WEB site.http://www.belkin.com/us/support/update
Mtv music generator detecting directx 7
ok... so I've now installed this on my new pc that i built... first in order to get it to install at all you must download DirectX 7.0 and right click to "--(edit compatibility settings to windows 98/Me and run as administrator)--" remember this as well be doing it a few times. once you do that install DirectX 7.0 and say yes to all. now that this is installed take the .iso file you have and burn it to a cd or DVD-r, once burned you need to go to my computer and right click on the cd/DVD drive, select open (NOT open autoplay), inside the disc menu i want you to go to 2 files... "setup" and "start" need to also have their compatibility settings changed to the above settings. now that these are set stay in the cd menu and double click "setup" this will take you through the setup procedure. after the setup procedure is finished do not view the notes, and continue back to the desktop. now from your start menu load the game and it should run
I cannot connect to the
you need more than a wireless adapter to connect to the internet......
you need a wireless network to connect to. in cafe's and pubs the owner sometimes sets up a WiFi network that their patrons can connect to, however most people have to provide their own.
to get to the internet , you will need.
A broadband connection (ADSL / Cable) this normally comes with a standard NON wifi modem
A WiFi Router (including ADSL / Cable Modem) depending on what you have already.
then to link a remote PC / Laptop to this network, A suitable wireless adapter ( like your belkin adapter)
it is a common misconception that a wireless adapter is all you need (advertising is vague)
