20 Most Recent Philips DVP5140 DVD Player Questions & Answers
3answers
The player says wrong region code
Where did u bought this DVD player?US,Canada,and Mexico?The DVD disc. used NTSC region format.Asia,Europe,Africa,and the Middle East.The DVD disc. used PAL region format.They can't be mix or it will not play as u find out.If u move in and out to another region of the world.U must have a regions free DVD player to play either NTSC or PAL regions.
1/7/2022 3:53:56 AM • Philips DVP5140... • Answered on Jan 07, 2022
2answers
"wrong region"
  1. Method 1:
  2. Open the disc tray
  3. Press SETUP
  4. Navigate to the preferences page
  5. Enter 138931
  6. Select the region using UP/DOWN
  7. Press PLAY
  1. Method 2:
  2. Open tray
  3. Press 9, 9, 9, 9, 0
6/2/2020 9:13:43 AM • Philips DVP5140... • Answered on Jun 02, 2020
2answers
DVD DOESNOT PLAY REAL PLAYER VIDEO
This model cannot play real player video files your model work on DVD, CD, and on the following compressed file formats:
Compression formats - MPEG1 , MPEG2 , DivX 3.11 , DivX 4.x , DivX 5.x , DivX 6.0
Your player can play only mpeg , avi , and divx, not real player .rm files. I don't think there are many DVD that can play real player files around.
1/3/2020 3:22:28 AM • Philips DVP5140... • Answered on Jan 03, 2020
2answers
Played French movie on region-free player and American movies won't work
Try changing back to region 1. Let us know if it works
10/28/2019 9:03:49 AM • Philips DVP5140... • Answered on Oct 28, 2019
Password after putting in the code (Philips DVP 3120)
Regarding my problem well it look me a while but I got there in the end. What I had to do was type in a password which is in the manual at the back 136900 & after that the DVD worked. The only slight problem I have though now is that when I do wana watch a region 1 DVD its asking for that password everytime I put one on, as long as it works all the time I should be ok.
Thanks.
5/5/2016 8:19:27 PM • Philips DVP5140... • Answered on May 05, 2016
Phillips DVP5140 dvd player
Sounds like there is a short in your AV cable. Move the video cable (marked with the yellow ends on it) and see it the color changes or use different set of av cables.
12/29/2015 5:02:59 PM • Philips DVP5140... • Answered on Dec 29, 2015
Code universal remote
try 12434 12205 12084 12056 11506 11389 11354 11340 11267 10675 10646 10539 10503
1/17/2014 5:44:10 AM • Philips DVP5140... • Answered on Jan 17, 2014
0answers
Remote code
Be the first to answer 11/30/2013 6:09:29 AM • Philips DVP5140... • Posted on Nov 30, 2013Be the first to answer
0answers
Htb3260
Be the first to answer 11/13/2013 5:15:17 AM • Philips DVP5140... • Posted on Nov 13, 2013Be the first to answer
0answers
Resetting forgotten philips dvd password
136900
5/24/2013 7:17:53 AM • Philips DVP5140... • Answered on May 24, 2013
2answers
How do i unlock the region code on my awa dvd
Got this one from the AWA tech - it worked for me
Turn Off Player
Turn On Player
Tray Should be closed
Using the remote choose 'Setup'
Using the Left/Right Arrow Key select The 'Preferences' Tab
Key in 8737
You should see a Box with the current Region Code
Use the Down Arrow key to change it to 0 (assuming you want region free) or select another number for a specific region
Hit enter (the play key) to exit this menu
Turn player off
Turn player on
load Disc
regards
4/5/2013 8:06:37 AM • Philips DVP5140... • Answered on Apr 05, 2013
0answers
2answers
New battery for technosonic portable dvd player
unplug 1st ! Open the unit.. look inside see if there is a nickel size battery in a clip on the ckt board. if you can, remove it and take the battery to radio shack to match it to a new one. put it back the same way you took the old one out. If you unit has a soldered in battery you will have to take the unit (if you can't solder) to a electronics repair shop. they should be able to fix you up for maybe $39 or so plus the cost of the battery.
1/13/2012 5:51:51 PM • Philips DVP5140... • Answered on Jan 13, 2012
Philips DVP5140 DVD Player Logo
139 questions posted
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
asks password
  • Televison & Video
