20 Most Recent
Black & Decker Black&Decker Home Cafe Single Serve Coffee Maker Questions & Answers
My black and decker home cafe will not dispense water
I work for Black and Decker customer support. Our customer service phone number is 1-800-231-9786.
If the unit won't dispense the coffee, it needs to be replaced. Unfortunately, the unit can't be
repaired. The unit comes with a one year warranty from the date of purchase.
Please call the number above so that we can determine your warranty
eligibility and help you in any way that we can.
While this doesn't actually solve your problem, I hope the information
allows you to make an informed decision as to how to proceed from here.
Please let me know if I can be of further assistance.
I have the Black and
With the problems you've described your iron having, it needs to be replaced. Unfortunately, the unit can't be
eligibility and help you the best way we can.
Black&decker home cafe
If the unit is failing to make coffee on a consistent basis, it needs to be replaced. Unfortunately, the unit can't be
eligibility.
My black and decker circular
I work for Black and Decker customer support. The customer service phone number is 1-800-544-6986.
Black and Decker tools have two year warranties except for the Quatum Pro Consumer Power Tools which have a three year warranty. If your tool was purchased within that time frame, please call the number above for the warranty procedure.
I hope I've answered your question to your satisfaction. Please let me know if I can be of further assistance.
Black and Decker whiper snipper
I work for Black and Decker customer support. Our customer service phone number is 1-800-231.9786.
If what you have is a Home Cafe coffee maker and it stops after a few seconds, the unit needs to be replaced. Unfortunately, the unit can't be repaired. The product comes with a one year warranty that begins on the date of purchase. If you purchased or received the unit within the last twelve months, please call the number above for our warranty procedure.
While this doesn't solve your problem, I hope that the information will allow you to make an informed decision as to how to proceed. Please let me know if I can be of further assistance.
The Home Cafe machine will not pump water
It's dirty or has scale / deposits. Use a paper towel to draw out as much water as you can from the "hole that leads into the machine" - then fill it with clear, distilled vinegar and let that sit for about 15 minutes. Fill the resevoir with a vinegar / water mixture. After the 15 minutes, run the vinegar solution through until the resevoir is empty.
After you do that, you will have to run several tanks of water through, to get the taste / smell of vinegar out, but the machine will work fine again.
Oily film
ok descale your coffee pot ( machine) with vinegar.
If it still does it it will be your coffee or the temp of the brewer is too low.
I am a coffee junk and have had this problem. If your water is too cold it sometimes happens but coffee brands do this too. Some brands roast thei coffee too long and that releases the coffees' natural oils.
No problem if the taste is good
I have black & decker pw1400s it is possible to connect the water faucet
It will depend on what kind of faucet it is. You can get adapters for the faucet on your kitchen sink but I find they are not very good for pressure washers. They can leak and spray water all over your sink and kitchen. For a pressure washer it is best to have an outside faucet fitted. This will give you the correct type of faucet to connect to and a good supply of water to the pressure washer.
It is usually not very expensive to get one fitted.
Black & Decker CM1609 keeps shutting off in the middle of making coffee
I had my black& Decker for about 6 months or so and it started shutting off after a minute or two of brewing. I cleaned it by running 5 cups white vinagar through it twice and using a filter in basket. Then running 2 pots of clean water through. I had to keep turning it on but by they end of later last pot of water rinse it stay on all they way through .there was an incredible about of lime built up . try it worked for me.
Model CM1609 received as a gift 2 months ago. From
I would not have waited this long to get a warranty replacement. If you need the proof of purchase, you will have to ask the person who gifted you. Hopefully, the giver will be understanding and help you out.
Trying to figure out how to turn off buzzer indicator on black & Decker Smart Brew coffee maker.
You cannot turn off beeping but i have found a 'hack' to do so if you are desperate, instead of caulking i would reccomend just simple blue tack/white tack...easier and also removable.
"Now if you want to squelch that beeping (this will probably void the warranty)...You can take off the bottom of the unit (but be advised you need a special screwdriver on one of the screws hidden under the rubber feet).
You will see a circuit board held by nylon standoffs, once you get the board loose you will see a round black unit with a hole in the top side, this is the beeper. To lower the volume so you can barely hear it fill the hole with caulking or silicone and reassemble. (be careful not to pinch any wires....Good Luck....."
STOP THAT BEEPING
