20 Most Recent Compaq Presario V5120NR Notebook Questions & Answers
Driver of sound
12/14/2012 12:00:15 AM • Compaq Presario... • Answered on Dec 14, 2012
My compaq presario doesnot produce
most probably u dont have the right driver installed.check on compaq or hp site about ur pc driver and it should start working.
9/2/2011 3:46:34 PM • Compaq Presario... • Answered on Sep 02, 2011
2answers
I am using Compaq Preesario
fiksyuh_3.jpg Software & Driver Downloads - Compaq Presario V5120NR Notebook PC
You can download sound and other drivers for your Compaq Presario V5120NR Notebook PC from the manufacturers website at hp.com. Simply select your operating system, then click 'Next' after visiting the Hewlett-Packard's website.
7/7/2011 9:00:02 PM • Compaq Presario... • Answered on Jul 07, 2011
Need a driver for audio,mass
Improve the Fixya.com experience for everyone by voting!
Click on the following link and enter the largest FREE driver database on the Internet: Driver Database.
All the best
Ben
5/29/2011 8:47:15 PM • Compaq Presario... • Answered on May 29, 2011
Need configuration of Compaq Presario
Hi, configuration details are- Compaq Presario V3155AU
AMD Turion™ Processor 2.0 GH, 512 MB RAM, 80 GB HDD, RJ45, 1394 connecter, 1 VGA slot, 1 expension slot, card reader, wireless network, DVD writer, N-Vidia graphics........
regards sathyamoorthy
11/15/2010 12:00:13 PM • Compaq Presario... • Answered on Nov 15, 2010
No sound on my compaq presario V2000 amd turion 64
I am unaware of the exact model of your notebook so please find them listed here with all drivers you will need.
http://h20000.www2.hp.com/bizsupport/TechSupport/ProductList.jsp?lang=en&cc=us&taskId=135&prodTypeId=321957&prodSeriesId=432985
10/23/2010 4:18:42 AM • Compaq Presario... • Answered on Oct 23, 2010
Is HP Pavilion dv5120us cpu upgradeable?
In almost all now laptops, the processor is upgradeable - within the same socket, and if the motherboard supports it.
With laptops, you need to know what you are doing, as you basically have to completely disassemble the system. If it is under warranty, take it to an HP certified technician in a HP approved shop, to maintain your warranty, as this would void your entire warranty otherwise. You could contact HP for which processors will work with it. Make sure to get paperwork and the old part, in the packaging from your new one from whoever installs it, to prove that a professional teck that they approve installed it, if you ever need service.
7/26/2009 2:42:55 AM • Compaq Presario... • Answered on Jul 26, 2009
0answers
How do I go about
No can do I'm sorry to say. Some laptops have restore partitions you can access but not Compaqs. You are encouraged to burn a restore DVD when you boot first time. You can run any licensed disc to reinstall and download the drivers from the Compaq site
12/18/2008 12:51:23 PM • Compaq Presario... • Answered on Dec 18, 2008
To update my compac realtek ac'97 audio
Hi there
I am going to tell you how to fix this problem step-by-step and best of all it's absolutely FREE.
1) Go to http://www.limewire.com and download limewire, once you have done this, install it.
2) Open limewire and type the make and model of your motherboard, then download one or more that you think should be suitable for your Laptop, then install them and you should be good to go! Please also remember to put a good rating on my profile.
Kind regards
Dustin Ellse
6/26/2008 7:05:21 PM • Compaq Presario... • Answered on Jun 26, 2008
Compaq AMD Turion screen problems
If it's going bad after an amount of time, it's either the solder joints on the video chip, or it needs the heatsink blown out,, which causes it to overheat.
good luck
2/12/2008 12:31:30 AM • Compaq Presario... • Answered on Feb 12, 2008
Compaq v5000 wont turn on
Shorted MOSFET in the secondary most likely.. These are trash..
1/13/2008 9:01:36 PM • Compaq Presario... • Answered on Jan 13, 2008
Compaq DVD Player problem
Does it show that it's playing? Check the software options to see if it's set to mute anywhere in there.
3/22/2007 11:26:50 AM • Compaq Presario... • Answered on Mar 22, 2007
Cq61 will not power up light flashes 3 times
In case somebody has the same problem. Result of my investigation: * If everything is ok then the Presario CQ61 boots without battery. * HP support recommends to do a hard reset i.e. remove power supply, remove battery, press power button to discharge everything internally, connect power, press power button In my case the problem was solved by changing the AC Adapter (Power supply). Note: The led besides the power connector is not reliable. It is on with the working and faulty adapter. Note: The voltage level at the battery pins is not reliable. I had same values.
9/22/2021 1:41:52 PM • Compaq Presario... • Answered on Sep 22, 2021
Compaq Presario CQ62 - Windows 8 Pro and Acrobat Reader X1.
old PC,, Cq series. cq62-nnnnn you left off the nnnnnn cq62-100, 200 ,300 what? running mS windows 8 HP does not support W8 on this PC so that means you are on your own steam... (you , it and microsoft 100%) forget ACER this is not and ACER PC< at all, (totally different) you could reload w8 , like you did before, now all that works its login password issue, can i presume the screens look ok W8login screens? local login fails, not bios, and not windows live logins fails that is right there are 3 tiers of logins. admin , create a new account and use that or do that and ask at MS how to copy date from dead account to new account, you never said once you had data. if no data on pc, then reload 8, easy no? the newer the OS the more hard it is to get data from that dead account( new permission rules, and hard to do) ask best i can tell, lacking your full model number teh CQ62-400 (newest) had only Windows 7 so how did w8 get there, from whome, and what media. and what install methods. from MS CD? or MS ISO, or from ebay hackers disks/ what? here are the ways, (not data recovery) http://www.pcdied.com/passwords.html
9/10/2017 1:44:07 PM • Compaq Presario... • Answered on Sep 10, 2017
My Compaq Presario CQ60 won't connect to wireless internet.
how'd you do 2012 post then 2017, shocking. some one needs new clock battery , LOL
8/30/2017 11:43:01 PM • Compaq Presario... • Answered on Aug 30, 2017
N OK sound after upgrade
check o see if your sound driver is compatible with new software operating system.
2/28/2016 3:15:25 AM • Compaq Presario... • Answered on Feb 28, 2016
What key combontion to turn on wireless capability
Find your model number near the serial number. With that number go to the following link and enter it. This link is for HP's support website. You can find everything about your PC, replacement parts, Drivers, Manual. HP Troubleshooting
6/10/2015 12:52:27 AM • Compaq Presario... • Answered on Jun 10, 2015
Computers & Internet Logo
22 questions posted
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Presario Compaq
  • Presario Compaq
Most Popular Question
audio drivers compaq presario v2000 amd
  • Computers & Internet
