20 Most Recent
GE Monogram ZVB36SHSS Stainless Steel Kitchen Hood Questions & Answers
I need a range downdraft up/down switch: J/N 625671 P/N 959-0402-00,01,02 C E140962 LN-121558-01. Any clue as to where I can get it?
These guys are Nucking Futs!... $85 for this dinky **** switch? What a joke, get createive and fix it your self (if you got the bad part) the most important thing is the black plastic connector... save the flex cable...you can buy a $3 switch at Radio Shack and kludge a switch to the flex cable your self... Got an OHM-Meter? Ohm-out the switch and find your "OPEN" circuit... The flex cable could have an 'open' due to the switch housing pressing down on the cable... Fix it your self and ust the extra $50 bucks to take your wife to a nice dinner! Kyd
My fan and lights stopped
You should check the lamps if they are ok and if you have a new one try to be 100%.
If not you should the fuse internal. We have here a
parts diagram and fuse is part no 170 and is a 5A fuse.
Finaly since the board is new and consider that the connections have been set correctly then you should check the light
transformer part no 208 in same diagram. Check whith a multimeter in and out voltage if it is ok.
Went to lower the downdraft
The switch that stops the motor when the vent is down was knocked out of position by the jump. Find it (it's on the lower lip) and fix it.
