20 Most Recent Sony Xplod (P589) Car Subwoofer Questions & Answers
As i play my stereo if i keep it at a lower volum
Hi and welcome to FixYa!
Yes the amp may be too powerful for the speakers but I doubt the protect signal. Let's just hope that the protect is working for you may damage the speaker if it ain't. I don't think that the speaker is faulty for there's no distorted sound even on high volume right? It's quite normal for the speaker to heat up but not to the extent that it will burn you.
Please have the amp be checked if everything is normal plus have a good look on the protect for I suspect that it's not working.
Hope this helps and thank you for using FixYa! Have a good one!
1/1/2011 11:19:34 PM • Sony Xplod... • Answered on Jan 01, 2011
0answers
0answers
With a kenwood amp 1000watt 170rms x 2 ,how should
You haven't supplied any model #s so its impossible to say - but Kenwoods don't normally like 2 ohm mono loads.
You're going to have to either use one channel @ 2 ohm... or use each subwoofer per channel on the amp.
For a 2 Ohm mono load - wire all positives and all negatives from each sub to the amplifier's respective (bridged) terminals.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question.
10/7/2010 4:26:43 PM • Sony Xplod... • Answered on Oct 07, 2010
0answers
My sub and amp are in workin order but my sub wont
Check your RCA cables, it may need to be replaced
6/8/2010 3:42:30 PM • Sony Xplod... • Answered on Jun 08, 2010
What amp do i need for Sony Double XS-L124P5B
Most professional car audio installers and manufactures say that to get the best sound out of your subs, you should run half of the RMS wattage listed on the speakers, which in your case would be 1300w for both which is kinda up there, but you can find a 1200w amp and even a 1000w amp would work great, just make sure that the amp has true wattage listed because they have a habit of over rating them until you read on it later. Another way of going about it would be 2 amps, 1 for each speaker, which would be smaller amps, but you would have to make sure both are getting the same amount. Hope this helps.
3/14/2010 10:46:47 AM • Sony Xplod... • Answered on Mar 14, 2010
My sony xplod isnt working, the wiring is all good
Make sure that the remote wire is still connected
11/17/2009 10:13:41 PM • Sony Xplod... • Answered on Nov 17, 2009
45w54 xplod. which wires do i use for the sub?
You want to get a wire that is capable of handling the output from your amplifier. Go down and see your local car audio dealer and he/she will advise you on the best gauged wire to install.
Trent
11/16/2009 8:31:37 PM • Sony Xplod... • Answered on Nov 16, 2009
I need a wiring daigram for subwoofer connection
Generally speaking most wiring set ups are the same for any sub and/or head unit.
Here is a diagram that you can refer to which has everything included, and if your just doing the sub to stereo you won't have to worry about the 4 channel amp in the middle or the speakers.
http://www.the12volt.com/installbay/uploads/amp_wiring_diagram.gif
10/26/2009 6:54:08 AM • Sony Xplod... • Answered on Oct 26, 2009
I got a double sub box off my friend and installed
blown coil
9/3/2009 8:02:01 AM • Sony Xplod... • Answered on Sep 03, 2009
2answers
Subs not working!!!
get a (aa)1.5 volt battey put a wire on the speaker touch one wire to the top of the battery one wire to the bottom of the battery if you hear a click or any noise from the speaker it ok if not it bad
8/27/2009 6:19:22 PM • Sony Xplod... • Answered on Aug 27, 2009
My sony sub isnt working, i checked the wires
do you have a power on signal wire hooked up?
6/9/2009 2:52:28 AM • Sony Xplod... • Answered on Jun 09, 2009
1 subwoofer stopped working in a box for 2
Hello mccanello55,
You need to remove the subs from the box in order to check the internal box wiring. First, make sure that the wire going from the nonworking sub terminals to the enclosure terminals is OK. Then check the "braided" leads on the back of the terminals going to the speaker cone. If the wiring all looks OK, remove the wires from the sub terminals, and use a multimeter set to the lowest ohm range and check the resistance across the subs terminals. You should read somewhere between 3-4 ohms. If the meter reads infinity (that is no reading at all), then the voice coil is open. If it "pegs" (reads "0"), the coil is shorted.
Either open or shorted means the voice coil is no longer working.
I could not find any replacement parts on Sony's support page, so it's most likely that they don't even repair these. They probably just replace the sub if it's under warranty, and if it's not under warranty, they probably recommend that you buy a new one.
Hope this helps.
4/13/2009 10:50:02 PM • Sony Xplod... • Answered on Apr 13, 2009
3answers
12" sony subs not working
If all co0nnected properly and working except the woofers only thing to check is to disconnect the bridge and try to connect regularly one woofer at a time to see if it still works.
1/18/2009 10:39:07 AM • Sony Xplod... • Answered on Jan 18, 2009
4answers
I broke the metal bit where the wire connects and dont know what to do
Sorry I'm not going to touch this one with a bargepole. I will suggest you go to a car hifi installer and get him to have a look at what a mess you've made and see if it can be fixed.
5/24/2007 5:08:06 AM • Sony Xplod... • Answered on May 24, 2007
One hits harder then other
A faulty voice coil may be to blame on one of the subs...when it heats up it starts to act up leading to a undesired preformance.
3/25/2007 9:38:18 AM • Sony Xplod... • Answered on Mar 25, 2007
Stuck in remote mode no remote
I think you mean Xplod?
Sony RM-X151 Car Stereo Remote -Electronics
Amazon.com https://www.amazon.com > Sony-RM-X151-Stereo-Re... Buy Sony RM-X151 Car Stereo Remote -Electronics: Remote Controls - Amazon.com ? FREE DELIVERY possible on eligible purchases. Rating: 4.3 · ‎100 reviews · ‎US$8.99 · ‎In stock
xplod remote control for sale
eBay https://www.ebay.ca > sch Remote Control For Sony CFD-G50 CDF-G35 CFD-G30 Xplod CD Radio Cassette Recorder. Brand New. C $14.93. Was: C $15.87 6% off. Buy It Now. +C $4.12 shipping.
Support for Remotes for Car Entertainment
Sony https://www.sony.com > electronics > remote-controls-... Questions & Answers · The remote control doesn't work · How to obtain replacement parts, accessories or software for a Sony product. · The remote control is not ...
Sony Car Audio/Video Remotes for sale
eBay https://www.ebay.ca > ... > Audio/Video Remotes Get the best deals on Sony Car Audio/Video Remotes when you shop the largest online selection at eBay.com. Free shipping on many items ' Browse your ...
Sony XPLOD Car Remote Controls for sale
thumpingcarstereo.com https://www.thumpingcarstereo.com > sony > sony-xpl... Sony XPLOD replacement Remote Controls for sale. If you've lost or damaged your Sony XPLOD remote control, don't worry, you can replace it!
Wgthhk Replacement Remote Control for Sony RMT ...
Walmart https://www.walmart.ca > ... > Home Audio Remotes Wgthhk Replacement Remote Control for Sony RMT-CG50A CFD-G30 CFD-G50 CDF-G35 Xplod CD Radio Cassette-Corder. Price when purchased online.
12/29/2023 2:41:06 AM • Sony Car Audio &... • Answered on Dec 29, 2023
Sony Xplod (P589) Car Subwoofer Logo
20 questions posted
Top Sony Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Car Audio & Video
Most Popular Question
  • Car Audio & Video
