20 Most Recent
Jensen VM9511TS AM/FM/CD/DVD/SD Player/7" LCD Car Video Player Questions & Answers
How do i hook up my ipod to this deck?
U must buy an adaptor cable, to plug the audio and video to the RCA jack of ur Jensen.
U could ask the nearest dealer about the adaptor accessories, I have one myself!
Hope that plugs everything up!
I had power to my
Double check the fuse and make sure that you are sending power to the radio. Check the fuse on the radio also important to check the ground and accessory wire too.
-david
I have the jensen vm9512
Hello eddyboy415,
I am really sorry to tell you that its your main board(mother board.)
You can look it up on ebay i pretty sure they have it.
i would suggest you to get new model if the mainboards(mother board) costs more than $100
Please let me know if you have any further questions or concerns.
Thanks.
How to play vidoes on
I assume you want to play a video that is stored on a sd card.To play this video you need to find out what is the compatibility of the player.A computer can play many formats, for eg it could be a mpeg4 format but this would not be able to play in any other player.There are few softwares that are readily available free of charge from the internet that would allow you to do a conversation of the format of the video.This way it will work on your player.Hope this helps.
Ipod 4th gen not charging on Jensen VM9311TS
The issue is that the 4th Generation iPod takes far more energy to run than your 4gb iPod. Updating the firmware has nothing to do with it. It's the amount of energy/voltage that this new 8Gig unit takes to run.
Think of it as a 4 cylinder verses an 8 cylinder engine. The 8 takes far more gas to run.
Blessings,
A/V Media Guy
Have problem with my control
to see if your remote is working obvouisly put in new fresh batteries turn on the camrea on your phone or get a digital camrea and point the infa-red sensor at the camrea and press some buttons while looking at the screen of your phone/digi cam should see a white flashing lights as you press the button if nothing then the control is dead
