20 Most Recent
Sony VAIO VGN-FS790 Notebook Questions & Answers
How do i install more ram?
Most laptopd can have additional RAM module installed from the bottom of the laptop. The RAM will be behind a screwed panel and maybe marked with M, remove this panel will reveal a RWM slot.
2/23/2012 10:16:04 AM •
Sony VAIO...
Answered
on Feb 23, 2012
Does the Sony VGN SF790 support hdmi cables? I
Hi.No I'm afraid not. It only supports VGA out. If your TV supports a PC input then a male to male VGA cable will do. VGA does not support audio so you will also need an audio lead to connect to the TV too.Regards.
8/13/2011 12:58:39 PM •
Sony VAIO...
Answered
on Aug 13, 2011
Sony vaio vgn-fs775p laptop real time clock not keeping time
Hi
thank you for your query
If the time is not keeping up then it would seem that you will need to change your CMOS battery, this is a small battery found on the motherboard responsible for clocking etc
The battery is cheap to purchase, however I do highly recommned the laptop be booked into a reputable PC shop for replacement as you will need to take the whole laptop apart to get the motherboard
I hope this has been helpful
7/19/2011 4:38:31 AM •
Sony VAIO...
Answered
on Jul 19, 2011
My sony vaio vgn fs790
It sounds like you may be having a video related issue. These issues may indicate that you have a problem with either your video card or your lcd screen. To isolate the issue, you have to connect an external monitor to the VGA port of the portable system. There should be an S2 button on your laptop which should allow you to switch videos. Press that and if the video appears on the monitor, then it is an issue with the LCD screen. If nothing happens, you have a video card failure. These are due for replacement already.
7/2/2011 7:59:05 PM •
Sony VAIO...
Answered
on Jul 02, 2011
I have a sony vaio
The built-in Motion Eye Camera is designed to add video functionality to many instant Messaging or video editing Software applications (such as Windows Messenger or MovieMaker). However the configuration process and support for how to set-up these individual applications is provided by the Software manufacturer, not Sony. Please contact your Yahoo Messenger support team for assistance on how to configure their Software.
TIP: Simply turning on your Computer activates that camera, so no specific
action is required to start the video services. Please note that only one
application can access the video signal at a time. If the signal is already
in use by one application, it will not be able to be detected by a second
Follow this procedure to take still image pictures with the integrated Sony Motion Eye camera.
1. On the taskbar, click Start and then click My Computer.
2. In the My Computer window, double-click the Sony Visual Communications icon.
3. In the Sony Visual Communications window, under Camera Tasks, click Take new picture.
Follow this procedure to capture video with the integrated Sony Motion Eye camera.
1. On the taskbar, click Start, point to All Programs, and then click Windows Movie Maker.
2. In the Windows Movie Maker window, on the left side under Capture Video, click Capture from video device.
12/12/2010 8:58:44 PM •
Sony VAIO...
Answered
on Dec 12, 2010
Neesito driver para una vaio
Acá:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=VGNFS790&LOC=3
Sino desde esupport.sony.com ingresa el modelo en descarga de drivers.
11/9/2010 4:20:17 PM •
Sony VAIO...
Answered
on Nov 09, 2010
How do I turn on
Hello, I think you can turn on your cam by clicking on the start menu and typing "camera" in the search option below, the computer should come up with the webcam software for you to use. But this can only work if you have installed the webcam driver.
I hope this solution has been helpful.
Have a wonderful day.
10/6/2010 7:33:54 PM •
Sony VAIO...
Answered
on Oct 06, 2010
When i turn it on nothing to see except broken
Please confirm if the lights are blowing on your notebook,
If you have any extra monitor try to connect that to the VGA Port of your Laptop. and switch it on. If display is coming on that Monitor it means the Laptop LCD having some issues.
9/24/2010 5:17:54 AM •
Sony VAIO...
Answered
on Sep 24, 2010
Code error 0xc0000185
Do you the Windows user suffer Error Code 0xc0000185 on your PC or laptop.
Well, this is a blue screen of a ***** error note telling me that your boot configuration info is missing (Error Code 0xc0000185)
This BSOD error code issues with a note - The Boot Configuration Data for your PC is missing some required information.
Causes of Error Code 0xc0000185:-
1. Suffer a cable attachment joining to your system and the hard drive.
2. Defective or missing boot files.
3. The disk drive gets damaged.
4. Wrong disk drive.
Solutions of Error Code 0xc0000185:-
1: Do sure that Wire is Correctly Connected [Only for PC]
2: Automated Repair
3: Check Hard Disk for Errors
4: Repair your System to Fix Error 0xc0000185
Full Solution -
9/14/2022 11:53:07 AM •
Sony VAIO...
Answered
on Sep 14, 2022
