20 Most Recent
Nuova Simonelli Premier Maxi Espresso Machine Questions & Answers
Machine won't turn back on need to reset
open right side panel cover and you can see the tank and heater.on the heater you can see a thermodisc that you can reset. also check if water is going inside machine like if pump is working.
I have owned this machine for about 5 years. a
There are a few things going on here, the pressure stat, the level probe and or the element or the safety reset thermostat. Since I cannot see the machine most of the recommendations here will be based on the info that was in your question. Since your machine looses power twice a day I will assume that your vent valve is damaged, and you produce alot of americanos. So check the pressure stat located under the machine(black or blue covered rectangular box) follow the tube leading out of it to the boiler, MAKE SURE MACHINE IS OFF AND COOLED DOWN. Check connection to boiler that could be blocked, if not blocked check tube for blockage. Then check the water level on the machine, it should not be past max on the sight glass. If it is your level probe needs to be adjusted and or cleaned, probe is on the right side of the boiler above the element, you will see a silver piece of metal with a red wire connected to it.
I have a Nuova Simonelli Premier Maxi . The is a
There is a level probe which is insert inside the boiler you should find it either on top or on the side of the boiler and with a wire conected directly on it. It also secure with 12 or 13 mm nut. You can anscrew the nut remove the probe whech is only a metal rod and this should be cover with scale or other water dirt. Put back together and the levelof the water will stop at the write point 2/3 of the boiler. Be careful to put it at the same psosition so you will not change the corrct level of the water. If it is very dirty then this mean that the whole boiler and machine need also descaling and cleaning.
Program error
Yes the flowmeter needs to be checked the impella or head needs to be replaced.
Nuova Simonelli Premier Maxi V
Has the machine been in cold storage? If no then the inlet solenoid could be the culprit. There might be sediment keeping the valve open.
I am looking at a
Hello there, the problem with your unit is most likely the control
board. With the power outage
Although you can try to do a reset of the unit. Here is a link to
where you can get the lowest prices for the genuine parts. First you
would need the parts manual to get the part number and also you can get a
complete user manual to enable you re install the the unit after changing parts. To reset the unit simply unplug it for about 5 mins this should reset the unit features.
Basically when the power failure came up it could have brought about a power surge which might have burnt up the control board hence the need for replacement.
Hope this support has been helpful?
Thank you
