20 Most Recent
Sony CDX-FW700 CD Player Questions & Answers
Trying to hook the right
The following should help you out. The first is for the vehicle and the second is for the radio. Good Luck.
Constant 12V+
Light Green
Switched 12V+
Yellow/Black
Ground
Black
Illumination
Light Blue/Red
Dimmer
n/a
Antenna Trigger
Orange/Blue
Antenna
Right Front
Front Speakers
5" x 7" Doors
Left Front (+)
Orange/Light Green
Left Front (-)
Light Blue/White
Right Front (+)
Dark Green/Orange
Right Front (-)
White/Light Green
Rear Speakers
5" x 7" Rear Door
Left Rear (+)
Gray/Light Blue
Left Rear (-)
Tan/Yellow
Right Rear (+)
Orange/Red
Right Rear (-)
Brown/Pink
Lost remote
go to sony.com and check with their online parts replacment center. You can order it from their
Sony CDX-FW700
The manuals for this product can be found at http://manualshark.org/p/sony-4/sony-cdx-fw700-1131/
No display
If you have tried another front & its the same, then its the main unit,...
Are the copper contacts clean? use rubbing alchol.
Are they intact? No? it needs to be professionaly repaired.
Sony CDX-M850mp isnt playing any audio from aux or cd input
This issue might be due to a malfunctioning auxiliary input or a problem with the amplifier circuit. You can try the following steps to troubleshoot the issue:
- Check the connection between the auxiliary input and the head unit to make sure it's properly plugged in.
- Check the audio cable for any signs of damage or wear.
- Make sure the auxiliary input is selected as the source on the head unit.
- Check the amplifier circuit to see if it's functioning properly. If it's not, the amplifier may need to be repaired or replaced.
If these steps don't resolve the issue, it's recommended to have the unit inspected by a professional audio technician.
