20 Most Recent
Rio SIRIUS Starmate Replay Receiver Questions & Answers
No sound from boombox
well im not sure of your level of experience in sound systems but check your fuse on your amp then check to see if your rca jacks are plugged in correctly to your deck then to the amp there is also a blue wire from the deck to the amp alot of people do not connect this and there for no sound it also goes from the deck to the amp and if your power wire from the battery with a fuse on it is not blown or even installed at all for that matter and the negative wire from the amp grounded to bare metal on the body of the car make sure of that hope that helps.
Its not turning on even in the boom box
Hello jimmytopps,
Unless the unit itself is defective, there's either a problem in the wiring or you have a burned out fuse. Check both the "always on" power lead and the 12V switched leads, usually yellow and red. Use a voltmeter and test each one to ground. The yellow one should read 12V with the ignition either on or off. The red one with ignition on or in accessory. If they don't, check the wiring and fuse. If they do, the unit is defective.
Hope this helps.
My starmate replay is also stuck on the sirius display
I do this repair for the ST2's. I can replace the SID chip and give your radio a new ID that you can activate with Sirius. I am on Ebay and my user
name is rarey57siriusXM. Look me up I also do LCD and scroll wheel
repairs for the Stiletto 10 and 100's. Cost of this repair service is
$24.95 and that includes free priority mail shipping back to you on all
these different repairs. Thanks
http://myworld.ebay.com/rarey57siriusxm
Sirius starmate 2replay has no sound. how do I go
When you hit the menu button go to FM transmitter and make sure is is turned on, and sellect a
frequency to set it to that is not being used by a radio station, tune you radio to the same frequency. if you are using the audio out on the starmate to plug directly into an aux in on you stereo, there should be a audio level adjustment in the menu as well.
Starmate 4 acquiring signal
With the antenna plugged in, it may take a minute to aquire the signal. If it takes more than a minute there is a problem with the antenna or the reciever.
Does anyone know the speaker colour codes for a
If they are paired together by color, you can turn the raido on and hook one speaker up and then use the fade and balance controls on the radio to figure out which wires go to which speakers
Help with code radio for my nissan pp2787h
The radio code is a security feature that's meant to deter theft, and it's unique to each vehicle. If you've lost your code, you'll need to contact a Nissan dealership or service center and provide proof of ownership. They should be able to help you retrieve the code. Please do not attempt to use codes from the internet as incorrect attempts may lock your radio.
Is there bluetooth on nsdn-w59
I have the same radio now with no Bluetooth am trying to get Bluetooth on it too without having to buy another radio. Please help.
No sound from wireless headphones in a toyota sienna
First thing to do is check to make sure that the batteries are properly charged.
Second, make sure that you have a clear line-of-site to the IR transmitter. Infrared (IR) works the same way that your TVs remote control works - if the signal is blocked, then you will not hear any sound.
Third, make sure that you are in the rear seat of the vehicle when listening to the sound. The IR transmitter only transmits to the rear seat, so you will not hear any sound if you are sitting in the front seats. This is a common problem that i see.
Lastly, make sure that the heapdhones you purchased are compatible with your 2006 2007 2008 2009 or 2010 Toyota Sienna. Remember that some older models require RF headphones, not IR headphones. I checked http://www.audiovideo2go.com for compatibility before I purchased my headphones. They have a useful listing of all the headphones and models of vehicles they are compatible with.
