20 Most Recent
GE 30 in.JGP330 Gas Cooktop Questions & Answers
Are replacement decals available for the heat
I Just called GE about this problem, wanna know their answer???Replace the whole stainless stell cook top piece for $325 ! ! !Customer Service, at its finest.This is obviously a GE problem , i live in a neighborhood of recently constructed homes, all of which have the same GE appliances, and all my neighbors are having the same issues.Gee, thanks GE
I just spoke to GE about this, NO, they DONT have decals, instead they want you to replace the whole Cooktop piece for $300 +...Am so annoyed.All my neighbors who have the same appliances put in by the builder are having the same issues. It's a GE problem.
Questions about replacing electric cooktop with gas (GE JPG331)
Hi, I can get you the regulator for $66.95. The part would have to be ordered. Yes it does need the regulator. I'm sorry but there are no generic regulators for this and for the safety of your family, you do not want to cut corners if possible. Yes you will need a threaded T to connect to existing pipe. Please let me know if I can assist you further with the [art.
THanks
Vic
Lamona ceramic hob
Ceramic cooktops need the correct type of pots or they leave marks,check your instruction manual.
2/17/2021 6:49:19 PM •
GE Cooktops
Answered
on Feb 17, 2021
KNOBS WON'T TURN
if the knobs wont turn, the cooker needs to be serviced by a gas engineer the gas taps are seized they need gas tab grease
11/1/2020 7:28:10 PM •
GE Cooktops
Answered
on Nov 01, 2020
Ge monogram induction cooktop error F
The induction cooktop will flash "F" when cookware has been removed from the surface; cookware is not present when the unit is turned on; or cookware is not centered on the element.
Position the cookware properly over the center of the cooking surface if the error code "F" flashes. Use only induction cookware and use a bigger pan, as the error code "F" indicates that the pan is too small for the cooking element.
1/9/2019 10:31:53 PM •
GE Cooktops
Answered
on Jan 09, 2019
