20 Most Recent Casio MS-80TV Scientific Calculator Questions & Answers
3answers
Casio seem to have a problem with the percentage key
The issue is the fact that you are adding the %. You need to Multiply it by 1.1 instead of trying to add 10%. This is a wonky equation anyway, because your not specifying what you want to add 10% of. This is why you are getting a weird answer.
11/2/2021 7:01:35 AM • Casio MS-80TV... • Answered on Nov 02, 2021
2answers
How do I change the tax rate on my casio ms-10vc
Please try the following...
Press AC twice. Hold down % set key for about 2 seconds until ?0? disappears on screen, then reappears. Press Tax Rate key. Input tax rate (12.5%) and press % set key. If this does not work, search for your model number here on Fixya and you will find other solutions posted. Good Luck!
2/19/2018 9:03:06 AM • Casio MS-80TV... • Answered on Feb 19, 2018
Set up tax rate on staples bd-9512
To set the BD-9512 (Staples Big Digit Tax Calculator) 1. Press ON/AC 2. Press and HOLD the RATE button (for 2 sec) 3. Enter desired Tax amount (i.e.: enter only 13 for 13%) 4. Press TAX + (or TAX - if setting the minus button) 5. Press RATE to save it. Violia!
6/12/2017 4:08:28 AM • Casio MS-80TV... • Answered on Jun 12, 2017
What is the percentage increase between 6,604 and 8,813
About 33.4%
9/15/2014 7:23:27 PM • Casio MS-80TV... • Answered on Sep 15, 2014
Tax-
The Tax- function allows you to take the total cost (sub-total + tax) and it will subtract the tax and leave you with the sub-total (before tax).
Example:
If the item you have is $5 and the tax is set to 5%... when you use the Tax+ key it'll give you 5.25.
Conversely, when you enter 5.25 and press the Tax- key and it will give you the base price of $5.
So the Tax- key removes the tax from the total amount.
It doesn't remove the percentage OF the total amount.
7/18/2014 9:42:05 PM • Casio MS-80TV... • Answered on Jul 18, 2014
125 as a percentage of 100
125 is 125% of 100.
6/15/2014 6:12:20 AM • Casio MS-80TV... • Answered on Jun 15, 2014
0answers
0answers
What is 65 is 64 percent of what number
65 is 64% of 101.5625 .
4/24/2014 3:03:03 PM • Casio MS-80TV... • Answered on Apr 24, 2014
What is the percentage of 63 out of 186
About 33.9%
4/15/2014 6:12:32 PM • Casio MS-80TV... • Answered on Apr 15, 2014
0answers
Installing new battery
Turn the calculator over. Look for some small screws that fasten a 1 or cover to the body of the calculator. Loosen the screws and remove cover. You should find button cell batteries. Before removing them make a note of the sign you see on the batteries (+ or -) while they still in place. Replace the batteries with the same model or equivalent ones. Replace the cover. For more detailed instructions consult your calculator's manual.
1/25/2014 1:19:54 PM • Casio MS-80TV... • Answered on Jan 25, 2014
3answers
Percentage button!!
they call it hardware malfunction. try removing all batteries in it and wait for 30 seconds before reinserting the batteries. If the same problem still exist, the unit is permanently damaged.
11/27/2013 10:29:15 AM • Casio MS-80TV... • Answered on Nov 27, 2013
I can't find a sac button on my casio fx-115ES calculator.
Which manual are you referring to?From page E-47 of the fx-115ES manual at http://www.fixya.com/support/p480502-casio_fx_115es_scientific_calculator/manual-19877, you clear the stat data by pressing SHIFT 1 3 2 while in the stat mode.
11/10/2013 4:55:46 PM • Casio MS-80TV... • Answered on Nov 10, 2013
0answers
9answers
RE: CASIO CALCULATOR MS-80TV
Non-printing models (also applies to HR-8TE printing calculator):
1. Press [AC]
2. Hold [SET/%] key for about 2 seconds
3. Press [TAX+]
4. Input the tax rate
5. Press [SET/%]
9/29/2013 8:59:36 PM • Casio MS-80TV... • Answered on Sep 29, 2013
10answers
Changing the % tax setting on my Casio calculator
step 1 pess the AC button step 2 press and hold for two seconds the % button step 3 press the tax+ button step 4 input 17­.5 step 5 press the % button that should be the tax set you can check it is set correctly by pressing the AC button and then the tax+ and 17.5 should be displayed
5/18/2013 12:37:39 AM • Casio MS-80TV... • Answered on May 18, 2013
Doesn't work out percentage correctly
Dear Plz try this 100 X 45% then press + and u will get the ans 145.
4/17/2013 5:04:24 PM • Casio MS-80TV... • Answered on Apr 17, 2013
H beam weight calculator
h beam 200*200*8*6 weight
4/1/2013 9:03:57 AM • Casio MS-80TV... • Answered on Apr 01, 2013
Casio MS-80TV Scientific Calculator Logo
113 questions posted
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Casio Office Equipment & Supplies
Most Popular Question
casio seem problem percentage key
  • Office Equipment & Supplies
