Kenmore 24 in.... | Posted on Feb 22, 2014 | Be the first to answer
Kenmore 24 in.... | Posted on Dec 22, 2013 | Be the first to answer
Kenmore 24 in.... | Posted on Dec 21, 2013 | Be the first to answer
Kenmore 24 in.... | Answered on Jul 30, 2013
Kenmore 24 in.... | Posted on Jul 25, 2013 | Be the first to answer
Kenmore 24 in.... | Answered on Jul 05, 2013
Kenmore 24 in.... | Posted on Dec 28, 2012 | Be the first to answer
Kenmore 24 in.... | Answered on Dec 01, 2012
Kenmore 24 in.... | Answered on May 08, 2012
Kenmore 24 in.... | Answered on Apr 06, 2012
Kenmore 24 in.... | Posted on Apr 21, 2011 | Be the first to answer
Hi
It seems that the power cord is either loose or not properly
connected assuming this as a new installation. If they are properly connected
then you can use warranty and get it checked as opening up the unit will void
the warranty. Please check this link to buy parts. Hope this helps...
Daniel
Kenmore 24 in.... | Answered on Jan 15, 2011
Kenmore 24 in.... | Answered on Sep 30, 2010
Hi, l
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Kenmore 24 in.... | Answered on Sep 29, 2010
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it's not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it's not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. There is a video of this at http://appliancehelponline.com/dishfloatwaterinletvideo.html this will walk you checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models. All parts come with installation instructions.
Kenmore 24 in.... | Answered on Sep 15, 2010
Kenmore 24 in.... | Answered on Aug 18, 2010
72 questions posted
-118 Questions
206 Questions
-78 Questions
159 Questions
138 Questions
