20 Most Recent
Epson PowerLite 76c Multimedia Projector Questions & Answers
Why is the Temp light on, and the projector not working?
Check your filter (clean it or replace it)
It is most likely clogged and causing your projector to overheat due to not being able to move air.
Why do you say you know it is the fan? Is the fan not coming on?
If the fan is not coming on then you need to check if the fan is getting voltage. Find a good ground and check the power pin with a mutimeter set on 20 volts or a volt meter,
If the fan is getting voltage but not turning on, replace the fan.
If it is not getting voltage it is a more in depth troubleshooting procedure. If you need further help, I’m available over the phone at
https://www.6ya.com/expert/gregg_27a4d257e54e7920
Epson 76C projector that the picture has no red
Youve probably got something gone wrong with your dlp chip with the million mirrors on it, see when the mirror tilts away from the light you get a black shade- tilted toward light lighter shade now throw the color wheel in which gives you color youve got green and blue so the color wheel is fine. Now how to replace chip? Dont. Look for a digital board or video board replace that and that should take care of ya. Good luck hope this helped ya-
Epson lq-690II printer reflects the paper when printing
Troubleshooting Paper Reversal in Printers:
*Confirm that options related to paper handling are set correctly by checking for specific buttons or switches that relate to paper handling or reversing.
*Ensure that paper is loaded properly to avoid feeding problems.
*Remove any dust, particles, or paper remnants from the rollers, as they can impede paper flow.
*If other measures fail, reset the printer to its initial settings to resolve potential software glitches.
EPSON 15140 error 034019
Try a hard reset of the printer. Oddly, the 034019 is not an error code, I have reason to think. It is a contact number, I believe.
Reset my Epson printer L382
Follow the steps given below to reset Epson L382 printer.
Step 1: Turn the printer off.
Step 2: Press and hold the reset button which is on the back of the printer using a paper clip or tip of a pen.
Step 3: Turn on the printer by holding the Power & reset button and continue to hold both the buttons.
Step 4: Wait for 5 seconds and a warning sheet will print. Release the reset button.
Step 5: After 5 seconds, another sheet will print which will show the IP address of the printer.
WHERE IS RESET BUTON? I CANT FIND IT.
I have Epson printer workforce pro c5790 shows error 000101, what is the solution for it ?
The error code 000101 on an Epson Workforce Pro C5790 printer typically indicates a problem with the print head.
Here are some steps you can try to troubleshoot and fix the issue:
- Perform a print head cleaning: From the printer's control panel, navigate to the Maintenance menu and select the option to perform a print head cleaning. This will help to clear any clogged nozzles or debris that may be causing the error.
- Perform a print head alignment: From the printer's control panel, navigate to the Maintenance menu and select the option to perform a print head alignment. This will help to ensure that the print head is properly aligned and is able to print correctly.
- Check for any physical obstructions or debris in the print head area, if you find any, remove it carefully.
- If the error persists after trying the above steps, you may need to replace the print head.
- If none of the above steps work, it is possible that the printer has a more serious problem that requires professional service.
I recommend you to check the user manual or contact Epson technical support for further assistance and specific troubleshooting steps for your printer.
