20 Most Recent
Epson PowerLite 62c Multimedia Projector Questions & Answers
The images are upside down
Your projector is in "ceiling mount" mode. I don't know all of the menus for your specific model, but if you navigate through the menus you will likely see an option for ceiling or table mount. This may be a picture rather than words. Also in the same menu list should be front or rear projection. A change to this will flip the picture to the correct orientation.
Dan
Why is my projector suddenly projecting pink?
Is it entirely pink or does everything have a purplish tint? Check the settings. If you are connected using component or VGA, make sure that the unit is set to RGB rather than YPrPb.
Update this with what you find.
Thanks,
Dan
My Epson Powerlight starts ok but the images have
Bay chip reset software from ebay or another place
for epson
http://cgi.ebay.in/Printer-Chip-Resetter-for-Epson-Reuse-Your-Cartridge_W0QQitemZ110521839309QQcmdZViewItemQQptZLH_DefaultDomain_203?hash=item19bb9d6ecd
I have an Epson 835
You need to change it to front/ceiling in the menu function of the projector.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Upside down screen Epsom emp s1
if you go into the menu and under settings (or service) you will find an option to reset the settings to factory default. select that.
Epson projector issue
I've found my solution. My troubleshooting info said to go to "signal" and make sure that "auto" was turned on. However, I couldn't find "auto" when I first tried. There are two places where signal comes up. The second one is under "set-up" and that is where you turn "auto" on. It works perfectly now. I hope this helps. For the icons, make sure you have "mirror image" turned on in your displays preferences if you're on a Mac. Good luck.
Problem hooking my macbook to the Powerlite 62c/82c the projector
For these types of projectors if you're planning to hook it up using you MacBook ;
You will need a converter ( from VGA to DVI )
Using the VGA cable that came with the unit when purchased ;
Connect the VGA cable on the back of the Projector and on the other of the cable you will connect the converter ( VGA TO DVI ) since for MAC systems it has DVI ports for monitors not VGA...
You can purchase the converter at any Mac store or any computer shop near you..
No illumination
make sure the power is coming on. if so, the contacts where the bulb is put in could be dirty/rusty/shot so you shoul make sure that is not the case and if it isnt then you should try calling customer service because there might be something wrong with the board.
Epson lq-690II printer reflects the paper when printing
Troubleshooting Paper Reversal in Printers:
*Confirm that options related to paper handling are set correctly by checking for specific buttons or switches that relate to paper handling or reversing.
*Ensure that paper is loaded properly to avoid feeding problems.
*Remove any dust, particles, or paper remnants from the rollers, as they can impede paper flow.
*If other measures fail, reset the printer to its initial settings to resolve potential software glitches.
EPSON 15140 error 034019
Try a hard reset of the printer. Oddly, the 034019 is not an error code, I have reason to think. It is a contact number, I believe.
Reset my Epson printer L382
Follow the steps given below to reset Epson L382 printer.
Step 1: Turn the printer off.
Step 2: Press and hold the reset button which is on the back of the printer using a paper clip or tip of a pen.
Step 3: Turn on the printer by holding the Power & reset button and continue to hold both the buttons.
Step 4: Wait for 5 seconds and a warning sheet will print. Release the reset button.
Step 5: After 5 seconds, another sheet will print which will show the IP address of the printer.
WHERE IS RESET BUTON? I CANT FIND IT.
