20 Most Recent Kenmore 66832 Dryer Questions & Answers
0answers
2answers
Dryer runs for about 20 min. then shuts off will
The only thing that can be is a bad motor. Both the run and start windings are going at the same time. Start windings are not dropping out. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
9/21/2011 2:16:29 AM • Kenmore 66832... • Answered on Sep 21, 2011
2answers
Loud squeeking noise when dryer
Greetings,
the belt pulley needs some lubricating..they squeek and the rollers thump...of coarse, its possible a stuck roller can squeek...The front needs to be removed..UNPLUG machine and if you have a removable lower access panel..this can be removed and lube the belt pulley.
if no bottom front., remove filter screws and raise top. there are two screws inside of front.Remove the front and you can lube or change parts as needed...
1/25/2011 11:33:03 PM • Kenmore 66832... • Answered on Jan 25, 2011
No heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
11/14/2010 11:26:14 PM • Kenmore 66832... • Answered on Nov 14, 2010
My dryer won't turn on at all. It was working
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
6/21/2010 5:14:13 AM • Kenmore 66832... • Answered on Jun 21, 2010
Not heating...replaced the thermal fuse and still
there is more than one thermal fuse in the unit.make sure to check the heating element for continuity as wells as your thermal fuses.
6/3/2010 3:23:08 AM • Kenmore 66832... • Answered on Jun 03, 2010
I have a Kenmore Dryer Model 66832. One of its
Air restriction such as lint build up in the vent pipe. The wrong vent pipe (rigid metal 4" is recomended), not cleaning filter after every load. Filter/blower housing in need of removal and washing out. Faulty control thermostat. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
12/24/2009 3:09:52 PM • Kenmore 66832... • Answered on Dec 24, 2009
My dryer starts and then turns off after 1 to 2
This is the result of a faulty timer control. replace the timer/control module asap if possible.
6/5/2009 8:37:08 PM • Kenmore 66832... • Answered on Jun 05, 2009
2answers
Dryer turns off after one minute.
Sounds as if your high temperature thermostat is going bad or is bad. Check your thermostats. If your dryer gets to hot this will shut it down for safety reason!
1/9/2009 12:38:54 AM • Kenmore 66832... • Answered on Jan 09, 2009
2answers
Drum spins off center and clothes get stuck between drum and casing
If your clothes get marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set.
Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it.
Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set.
Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
4/23/2024 11:52:33 AM • Kenmore Dryers • Answered Yesterday
2answers
Trying to find out how much part #7 on the exploded view of the Kenmore elite electric dryer model 110.2808 is? It is a motor.
110.2808 is an incomplete model number. Motors are typically $140 to $180 USD https://www.easyapplianceparts.ca/PartInfo.aspx?inventory=334304&SourceCode=18 This is is a typical Kenmore model designation and is probably the matching washer to your dryer. Yours is missing 4 numbers. Label in the back, label on the door frame, mentioned on the manual.
Model # 11028081700 Official Kenmore Elite washer
https://www.google.com/search?q=Kenmore+elite+electric+dryer+110.2808 ..
2/23/2024 6:44:28 PM • Kenmore Dryers • Answered on Feb 23, 2024
Is it possible to reverse the direction that the door opens on Kenmore Elite Quietpak 4?
Yes, it looks like you can. Don't forget though that you have to get inside and move the door switch. https://www.google.com/search?q=Kenmore+Elite+Quietpak+4+reverse+door ..
1/26/2024 12:16:00 AM • Kenmore Dryers • Answered on Jan 26, 2024
Kenmore ELE-2406028 Laundry Dryer. Help with door switch replacement.
It is an easy enough job. The videos show how. The parts are here https://www.google.com/search?q=Kenmore+ELE-2406028+door+switch ..
1/2/2024 4:11:27 AM • Kenmore Dryers • Answered on Jan 02, 2024
8546206 tech sheet
What is the question? Do I have the tech sheet? Yes I do.
12/17/2023 6:48:07 PM • Kenmore Dryers • Answered on Dec 17, 2023
Looking for age of Kenmore gas dryer Model 110.77741600
The are various idea here.
I have model and serial #s for my washer/dryer. What year ...
iFixit https://www.ifixit.com > Answers > View > I+have+m... Apr 3, 2017 - I have a Kenmore washer and dryer. I have the model #s and serial numbers. I need to know what year ( how old are my appliances?) of the models. 4 answers · Top answer: Erin Morrissey , How to find out the manufacture date of a Kenmore washer or dryer by the ... How old is my dryer? - Kenmore 110 Series ... 2 answers Mar 11, 2022 How old is my kenmore washer/dryer combo? - iFixit 2 answers Aug 4, 2018 help me find out how old this washer is - iFixit 2 answers Sep 29, 2021 What is this dryer model number? - Kenmore Elite ... 2 answers Jul 18, 2016 More results from www.ifixit.com Missing: 110.77741600 ‎' Show results with: 110.77741600
Can you tell me the age of a dryer from the model or serial
JustAnswer https://www.justanswer.com > Appliance Repair May 19, 2023 - Can you tell me the age of a dryer from the model or serial # Kenmore 600. Model is 110 78652700 serial is - Answered by a verified ... 1 answer · Top answer: Good afternoon. My name is ***** ***** I'll be assisting you with your appliance today. Please ... Missing: 110.77741600 ‎' Show results with: 110.77741600
12/15/2023 2:51:24 AM • Kenmore Dryers • Answered on Dec 15, 2023
2answers
Kenmore 66832 Dryer Logo
14 questions posted
Top Kenmore Dryers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
View Most Popular
Kenmore Dryers
  • Kenmore Dryers
Most Popular Question
dryer runs about 20 min shuts off will
  • Dryers
