20 Most Recent
Dell OptiPlex GX150 PC Desktop Questions & Answers
To buy a Dell Computer
if it says refurbished or recertified ... it's used
Robert
Please take a moment to rate this solution thanks
How can I boot from cd by pressing a button
as sonn as you turn on your unit continuously press F12 before the windows logo shows. this will take you to bios where you can change boot options. Make your cd/dvd/ the first pop in disk save settings and exit unit will reboot then tell you to press a key to boot from disk you only have about 3 seconds before pc boots normally
How do you set original boot configuration or can you make the desktop automatically do it?
When you turn on the power, start pressing the F2 key. This should bring up the BIOS screen that will allow you to see what the settings are for the computer hardware. Make sure that you check the date and time because this is an indication that the battery in the computer is dead. If the date and time are correct, then look for the screen that shows the hard disk drives. If none is shown, then it be an indication that the hard drive has failed. IF the drive is shown, then you can look for the screen that shows the boot device order. Usually the CD drive is listed first and then the hard drive.
If you did not change the boot order or any of the settings in here before this happened AND the battery is not dead, THE HARD DRIVE has most likely failed.
I cant log into facebook
Please check your PC for any errors or virus in the system as the server might reject if there are systems logging in with malwares.
use a good anti virus and scan, Also to confirm try and log in from a friend's PC. If this works then the PC is having errors in the OS.
3rd party antivirus cannot remove without password computor usage goes to 100 percent when tryinging to go to internet
Restoring a computer to its original factory settings should be the last ditch effort in attempting to save a system that has been corrupted by viruses or defective programs. In the best case scenario, one would use the system restore CD that ships with new computers but often this CD is lost or the computer was purchased used. In this case, a factory settings restoration can still be performed by using the computer's "Advanced Boot" menu. Restart the computer. Press the "F8" key after the computer reboots but before the "Windows" logo appears on the screen. You should now see the "Advanced Boot" menu. Scroll down through the menu options using the down arrow key. Stop when "Repair Your Computer" is highlighted and hit the "Enter" key. Select the language you wish to use and press the "Enter" key. Type in the computer's administrator ID and password. Press the "Enter" key. Scroll through the options using the down arrow key. Choose "Restore (name of computer manufacturer) Settings." Press the "Enter" key. Choose "Yes" when asked if you want to reformat the hard drive. Press the "Enter" key to begin the reformatting process. The process takes a few minutes, so be patient. Do not turn off the computer or attempt to stop the process after it has begun, or this may result in major damage to the hard drive. Choose "Finish" and press the "Enter" key to restart the computer. The computer will restart with the original factory settings.
Dell dcne wont start light is solid orange
i removed the connector at "J5J3 pswrd."this is the blue thing between the battery and the card slot.i tried everything else such as new M/B battery. remove/change ram. take out extra card, etc.I just fixed my dell dimension 3100 by doing this.
My dell optiplex gp150 doesn`t connect to internet it show error 12007
if you want to know what this is the error code is related toclick start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
you will have to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ? you will need to update or install the driver or it could be firewalled
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question / exclamation mark ? ! or a red X right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all o fyour internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabledimake sure its enabledPci device arrows key scroll to nstalled.
hope this helps
Download nic
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router. To fix this problem, right click on the wireless icon on the Task bar and then click Repair. This will force the wireless router to issue a IP address to the wireless card on the laptop.
Dell optiplex gx150 cd drive won't boot
Hmmm--when you went into the BIOS setup, your first boot device should be CD. The next your hard drive. The other boot devices should be set to disabled. Now if you have a third boot device as a network device, then your computer is not seeing the CD or the Hard drive--you have a problem. If all the drives are hooked up properly (sounds like you have that covered) then your motherboard is probably the problem.
I would try to disconnect all your stuff except the CD. Try it on the first IDE channel (set it either as cable select or master). If that fails, try it on the other channel. Do you have a second CD to swap out?
Still no boot? Bad motherboard.
Fix it toolbar
You have neglected to state the problem so im note sure what the problem is a guess is in orderto create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
click on the tools at the bottom of the drop down list will be internet options or
click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in google.com) or your preferred home page and browser
below that will be change search defaults click on settings you will see all search providers you have if dont need any of them you can disable or remove them
hope it helps
Will the hard-drive from PACKARD-BELL IMEDIA X2414 go into DELL GX150LINUX
Yes if the data connections are compatible. SATA data interface and SATA power connector, it's a thin black connector.It is not reccommend to switch drives across operating systems unless you are abolutely sure that you know how to access the drive without damaging/erasing the information that is currently on the drive.The current Windows hard drive will not boot in a different pc system. I would suggest getting the orginal pc working again, it may be a simple case of loose connection/contacts. Unless you had a friend that would be willing to help, by attaching your hard drive to his pc as a slave and then copying your data to DVD's.See my published guide entitled:
My Computer is not turning on!!! Is it dead!!! No POST!!!Take care!damnor01
