20 Most Recent
Oster 76076-040 Hair Trimmer Questions & Answers
THE SWITCH IS BROKEN OSTER TITAN CLIPPER.
If the clippers are less than a year old send them back too your supplier, if not you can send them to our servicing department or alternatively fit a replacement switch.
OSter Titan hair clippers
Oster titan blades. I have had mine for 5 years.
Oil one is a little ball on the side of clippers push in with oil tip. Make sure your clippers are running for this. You also have to grease them once in awhile with clipper grease. You should have a front panel that has screws. open and grease put case back on. for cord you can try an oscar fix place or try and see if the company will replace if you have not had them long. hope this helps.
Broken clippers
www.oster.com/ServiceCenters.aspx lista many service centers accross the country.
I suggest one like
Shaver Service Center
5320 Cameron Road
Austin , Texas
78723
Phone: 512-454-5848
Fax: 512-454-9432
[email protected]
http://www.shaverservicecenter.com
Email them, or one like them with your special situation and I suspect they will help you with RUSH SERVICE.
Keep up the great work you are doing over there, and stay safe!
Oster clippers
Found another web site where some one had posted the information I needed. I just used Google search and found the information.
Greasing the oster titin
Just a few drops of light oil directly on the blades themselves. This should make a world of difference. good luck 3 in 1 oil will work sewing machine oil or somthing similar. I have also used some fancy spray lubes in the past with good results.
Where do i put the oil to oil the blades
When oiling clippers you want to have them running and tilted blade down toward the floor. You put about 3 small drops right on the running blades. Then wipe off excess oil with a towel. You dont want the oil running back into the motor of the clipper. You should oil them about every other use. Good Luck!
I'm looking for an owners manual for Oster electric knife and scissor sharpener model 522
eBay sale item may be similar to yours with a manual:https://www.ebay.com/itm/VINTAGE-OSTER-Double-Action-Electric-Knife-Sharpener-W-Manual-USA-Model-522-/153587369882For link below, registration is required, and I have not personally registered to verify it. Apparently a 1950's device that may need to be serviced or replaced. https://free-downloads.online/7711-0-c5e0c2f6/signup-blitz/#/theme=dark/c_bg={c_bg_enc}/z=51155/dp=2906786074.538571.44fa3ae453.33665.1c1e01e67e064c41c94abed63baaec57/q=Oster+knife+sharpener+manual/
