20 Most Recent
TCL LE24FHDD20 24-Inch 1080p LED HDTV Questions & Answers
Need Time Warner remote codes for a TLC TV
There are no Time warner codes for TCL tv's. You will have to perform a "code search"1 Turn on the device that you wish to program. If you are programming a DVD or VCR player, then insert a media disc such as a DVD or VHS tape.2 Press the device key on the remote once. This remote is capable of programming five devices, and each has its own respective button at the top of the remote. For example, if you wish to program a TV, press the "TV" device key at the top of the remote. The device key will blink once.3 Press and hold the "Setup" button on the remote. The selected device key will blink twice, indicating it is ready to be programmed.4 Enter "991" on the remote. The device key will blink twice again.5 Aim the remote at the device you wish to program and press the "Power" button.6 Press the "Channel +" button on the remote. Continue to press that button until the device turns off. Once that happens, press the "Setup" button to lock in the code.7 Press the "Power" to turn the device back on and it will be ready to use
Tcl l40f10f
try update your TCL TV firmware by current update version file from USB stick
https://electronics-tricks.blogspot.com
Tcl tv repair
It sounds that the main system control
memory IC is faulty. Replace it and check. This is a very cheap to buy IC. Eventhough its cost and size is small, the function of it when the set is switched ON, is great. It is a very small IC, having only 8 solder terminals. If
you wish to get more details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic
/ Time slide, can be selected by the drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window
