I'll take it that your computers clock is not keeping time/date or you get a checksum error.
1. Unplug computer and open it up
2. Locate the battery holder and carefully remove the battery from the metal tab
3. Replace battery quickly
4. close computer and start up
5. Press F10 and reset cmos values to default
6. If nothing has been resolved you have bad hardware or a faulty motherboard.
This error might occur after installing a faulty device driver, system service, or firmware. So ask yourself, Have I installed any new devices lately?
The Stop message may list a driver by name, disable, remove, or roll back the driver to correct the problem.
Try to disable or remove the drivers and see if this resolves the issues.
If it does, contact the manufacturer about a possible update. Sometimes manufacturers know about issues and make fixes.
This message can also be caused by failing or defective hardware. If the Stop message points to a category of devices, try removing or replacing the hardware to see if it is the root of the problem.
the BSOD bluescreen can be caused by a number of things
you might not have enough RAM random access memory not having enough will cause your computer to run over its maximum limits and can cause the blue screen of death and hang and cause memory dumps
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to
compatible ram also you will have an option to scan your system
you should always ask the seller if they guarantee the compatability of the ram before making any purchaseif you dont want to install more ram uninstall some unnecessary programs
make sure your ram modules have a dust free secure seating and the CPU central processing unit has thermal paste
a bad or faulty motherboard data lead or its connection if its a flat 40 pin ide it will be the first to failmake sure all leads have a dust free secure connections
a bad driver loose or faulty lead or not having enough ram
if you can get a screen
click start control panel administration tools computer management device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download one
or it might be a virus right click in bottom toolbar select task manager applications to see what is running and processes to see what is ticking over
hope it helps
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope it helps
if you are referring to a usb drive
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programsClick on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope it helps
110 questions posted
2,074 Questions
1,169 Questions
1,075 Questions
718 Questions
514 Questions
