20 Most Recent
Samsung UN60D6000 60 Inch 1080p Smart TV LED LCD HDTV Questions & Answers
Will not turn on
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
5/22/2016 3:50:16 PM •
Samsung...
Answered
on May 22, 2016
Won't turn on..no picture..red light blinks constantly
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
If blinks continue without any pause, the main board is faulty.
4/10/2016 12:12:12 PM •
Samsung...
Answered
on Apr 10, 2016
Screen is start fade with black half way down screen now sound good
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
2/25/2016 5:15:15 AM •
Samsung...
Answered
on Feb 25, 2016
I cant watch youtube on my tv
It has to be connected to the internet and the settings have to be correct for it to communicate with the router.
8/12/2015 11:26:59 PM •
Samsung...
Answered
on Aug 12, 2015
